Disc Repair help
/ Disc Repair help
I called Agri Supply. The women I spoke to couldn't have been less helpful if she spoke a Russian. Knew absolutely nothing about discs or my questions. Would've been just as good to call Applebee's and asked them.
/ Disc Repair help #22
No need taking them apart to repack. I just fill them with the grease gun it probably has 2 grease fitting per spool.
Next time go ahead and call Applebees ,order you something to eat, then go online to Agri Supply. I have never had much luck with callling them except to check for availability of a part. :)
/ Disc Repair help
Yeah, they have two zerks each. The ones I had to disassembled where so packed with crud I am not sure grease wouldve flowed through them. We shall see. I got the bearings today I needed. Should be an easy reassemble and install of the gang I removed.
/ Disc Repair help #24
Schoup. Download a catalog. Don't expect them to help you. You are not their business model customer.
They can build a square shaft. You will have to buy the right ends. Most square shaft are forged, using a block to evenly apply clamping force to the concave and convex gang ends. A stamped and welded end saved a lot of expense on your disk.
Your deer plot disk isn't a farm tool but built for dear plots.
Build an acorn nut to protect the exposed threads.
/ Disc Repair help
Got everything reassembled and greased. Seemed like the inner most blades not eh front gangs were gonna collide, Just moved the two L shaped iron brackets to the opposite side of the angle iron frame. think i got a enough space now. Need to get back to the farm to disc and plant
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
1988 KALYN HRGP-30-40T LOWBOY DETACH TRAILER (A59823)
1988 KALYN...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
