Disc Mower Tips
   / Disc Mower Tips #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
As you know I have broken out a couple window in my cab with my disc mower on a mower caddy. Well, I just finished up 100 acres with no broken windows. I raised the front of the mower a tad more (3 turns on the 3 point) and it is throwing nothing now. Also, the grass is in better shape so I am much happier with things. I am still planning on building a rear guard, but it is not as urgent now.
I am learning as I go, I am not fortunate to have a mentor guiding me here.
So, you can have the mower too low and well with a mower caddy it puts it in a better spot to bust out windows.
D.
   / Disc Mower Tips #2
D. - glad to hear that you're makin' things easier for yourself... can't be much fun pickin' glass outta everything and then payin' for a new one!
And, it's always a rougher ride when you don't have somebody to point out the bad spots in the road before you go through 'em!
How many cutting does this one make for the season?
Best of luck.
AKfish
   / Disc Mower Tips
Best of luck.
AKfish
Yeah - making progress. When those windows break - it will wake you up for sure.
2.5 cuttings seems to be the norm. I got a godo 1st cutting. A horrible 2nd cutting (no rain) and I am doing the 3d which most would call my 2nd to be honest. It is looking good. I have all 100 acres cut. Front 33 acres is raked and I am baling it. Wife is in the back 66 acres raking it up. So far 23 bales and I think I have covered about half of that front pasture.
D.
   / Disc Mower Tips
Thanks for the tip Darin.
Are you slinging rocks I'm guessing?
I was slinging rocks, it is much better now. I broke out a side window in the first cutting and the main rear window on the 2nd cutting. I made it thru this cutting with no broken windows.
We sprigged these pastures in 3/07. New pastures, not totally covered yet - it happens.
I am on track to maybe make 250 bales off them this year so I can't complain too much for a new pastures I guess. Especially considering this is the first year and it has been pretty dry.
Also, those rocks will get into everything. I have one get stuck in the pickup reel auger. it jammed the pick up reel clutch and wasted it. My dealer told me you get 3 slips and it is toast. Since I bought it used, who knows how many times it has slipped. I put a new one on it a couple week ago with a new chain. I am going to add the slip clutch system to the baler. $250 or so for the parts. It will alert you if the main drive clutch or pickup clutch is slipping.
Some people will tell me I am fool if you don't hear the pickup clutch slipping but that is not always true. In a John Deere cab - it can be hard to hear. Open the rear window and it is obvious what is going on.
D.
   / Disc Mower Tips #6
So what does that making your mowing height? Seems the front skirt would catch the rocks but I guess it didnt (at least some of the time).
   / Disc Mower Tips
I do not know. I'll measure it once I hook it back up to clean it up.
Where do you run yours?
D.
   / Disc Mower Tips #8
Dont own one yet...but when I do itll be a Kuhn pull behind....at least based on whats currently available. I dont have a cab on my tractor but mow at between 3 and 4" (closer to 4 than 3) w/ my current mower.
   / Disc Mower Tips
What kind of mower are you using?
Are you cutting hay?
D.
   / Disc Mower Tips #10
I have never actually measured the heighth that I cut at. I have always adjusted it by whether it "looked" right or not. 3" to 4" is about the right height from all that I have read. If the tips of the blades are showing a lot of wear quickly or if you see a lot of dirt or dust coming out of the cover, it is set too low. On the Krone's the cover should look level or even a bit high in front. I wear steel toed boots usually and when I hook a mower up I want to be able to slide the toe of the boot under the front of the blades and have room to spare. For me if fields are rough, have quite a few small rocks or gopher piles I generally set it to cut a bit higher if I see it trying to kick up too much dirt ect. I had a customer put me in a field this year that he said was mowed last year and "they didn't have any trouble". It is amazing how far one of these mowers can throw baseball sized rocks.:mad: I ended up changing 4 blades and walking out the area that had rocks in it. I noticed that he didn't say anything about the skipped area in the field.:rolleyes:
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
2016 JOHN DEERE 8245R LOT IDENTIFIER 230 (A53084)
2016 JOHN DEERE...
