Disc how much
   / Disc how much #1
void777
South Mississippi
YM 2000
How big of a disc can I work with a ym2000 fairly soft ground until August :confused3:
   / Disc how much #2
5 foot will be the max and then that depends on how heavy aND how many and what size disks. But assuming a very light say like Howse model you probably will have to control the depth or else it will han you up.
My LMC disk is about 4.5ft wide and has I think it's 12 disks 16" in diameter. And when there cutting and buried up to the axles it's all my tractor wants.
   / Disc how much #3
How much does your tractor weigh?
How much horsepower?
2-WD or 4-WD?
Rear tires filled with air or liquid?
   / Disc how much #4
it will help to load your tires too
   / Disc how much #5
He has a YM2000 if I am not mistaken. So it's 24 engine HP. Weighs about 1800 pounds unbalsted and is 2wd.
   / Disc how much #7
He has a YM2000 if I am not mistaken. So it's 24 engine HP. Weighs about 1800 pounds unballasted and is 2wd.
MAYBE could pull Disc Harrow with 16" diameter pans for Secondary Tillage; i.e.: leveling plow furrows or working a kitchen garden annually. Implement only as wide as outside-to-outside tire width.
OP says soft ground, so draft force will be high.
DH1048: http://www.landpride.com/ari/attach/lp/public/specs/322-013s.pdf
Tractor does not have enough weight nor horsepower to pull a Disc Harrow for Primary Tillage; i.e.: breaking ground.
Primary Tillage requires pans of 22" diameter or greater.
Better to shop for a PTO powered roto-tiller.
Roto-Tillers and Disc Harrows are both soil mixing and smoothing equipments.
   / Disc how much
2 wd tires are foam filled was filled before i bought it wt 1500lb + fill
   / Disc how much
Guess its time to look for a rotor tiller it might be best idea thanks for the help people.
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
