Disc hiller/bedder single disc vs double disc ?
   / Disc hiller/bedder single disc vs double disc ? #1
mike35549
Bronze Member
Walker Co. Alabama
Mahindra 2538 with FEL
I am going to purchase a disc hiller the question I have is what is the diffrence between the ones with one disc on each side vs the ones with doubles on each side. The ones with doubles cost quite a bit more just trying to figure out if the price is worth it. What size disc do most people use.
   / Disc hiller/bedder single disc vs double disc ? #2
I adapted a cultivator to use as a hiller;works pretty good and still have the use of the cultivator when needed.
All bolt on.
Note;disc were turned after picture was taken(back-wards in pic.)
   / Disc hiller/bedder single disc vs double disc ? #3
A friend of mine gave me an old soil ripper, which is a tool bar with cultivator tines, from his JD M. I designed the conversion to 3ph, and he helped make it, as he still worked in a machine shop part time.
Below is a picture of my disc hiller arrangment to make raised beds. I bought 20" discs from Agri Supply.
Agri Supply has a tool bar gizmo called a Keulavator that would work for this.
Ralph
   / Disc hiller/bedder single disc vs double disc ? #4
I have a single disc (each side) hiller/bedder...not sure what advantage a second set of discs would be...I did add a small (shallow) furrower to the center and I added a couple of 'S' tine sweeps that are set to cover my rear wheel tracks...
How far apart and at what angle do yall set your disc.
   / Disc hiller/bedder single disc vs double disc ? #6
The bedder I have has 3 blades per side.
   / Disc hiller/bedder single disc vs double disc ? #7
I am convinced that I need a hipper/hiller as well. Stevenstractor.com has this for $650. I'm considering the time/effort of building one out of an old disc harrow and a toolbar that I have. Anyway, take a look and tell me what you think, please. (BTW, I have no association with the dealer.)
Deluxe Row Hipper - YouTube
   / Disc hiller/bedder single disc vs double disc ? #8
   / Disc hiller/bedder single disc vs double disc ? #9
It depends on how wide of beds you are making and how big of discs you have. I make 3' wide beds (3' at the base not at the top) and I use 16" single discs. they work fine but that is all the wider I would want to go with a single disc and a 14" disc wouldn't get me enough dirt moved.
   / Disc hiller/bedder single disc vs double disc ? #10
I have hilled potatoes with single discs in the past and it was good but not good enough since the dirt did not pile high enough to fully cover the plant. The addition of a second set of discs behind the first one fixed that problem so I would say for this purpose, two sets were better than one.
2014 Nissan Quest Minivan (A42744)
2014 Nissan Quest...
2013 INTERNATIONAL TA005 (A45046)
2013 INTERNATIONAL...
2012 Nissan Titan SV Crew Cab Pickup Truck (A44572)
2012 Nissan Titan...
2012 LARK UNITED CARGO TRAILER (A45333)
2012 LARK UNITED...
2018 Dodge Charger Sedan (A42744)
2018 Dodge Charger...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
