Dis-similar metals question
   / Dis-similar metals question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Is there a chart or something that tells me what metals can and cannot be next to each other?
I think Galvanized and Copper are a no no but what about regular steel and copper?
Love any insight anyone has.
   / Dis-similar metals question #2
Look for
Anodic index table
Here's one:
Galvanic corrosion - Wikipedia
"For normal environments, such as storage in warehouses or non-temperature and humidity controlled environments, there should not be more than 0.25 V difference in the anodic index. For controlled environments, in which temperature and humidity are controlled, 0.50 V can be tolerated. For harsh environments, such as outdoors, high humidity, and salt environments, there should be not more than 0.15 V difference in the anodic index."
Copper and steel have a difference of 0.50V
Some stainless steel has a difference of 0.15V
The closer the metals on the list, the less corrosion
Bruce
   / Dis-similar metals question #3
If you can manage to figure out how to weld them together,, Hmmmmmm???
If corrosion is a concern,, simply protect both metals after joining,,, paint them,,, corrosion becomes a non-issue.
Corrosion is an issue,, only if the metal can corrode.
If you want to join copper to steel, braze them, silver solder them,,, then paint.
Welding is a difficult choice only because of the thermal conductivity of the copper.
Galvanize is simply a zinc coating on steel,,, like paint,
if you try to weld galvanized steel, the first thing that happens is the zinc coating burns away,,,
you are left with,,, wait for it,,, steel.
Joining two materials together is like making a battery,,, like the battery in your car.
If you insulate the materials after joining, like painting them,,, it is like having a disconnected battery,
nothing happens.
Freightliner Fuel Truck (A56438)
Freightliner Fuel...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
