dirt work 5075m
   / dirt work 5075m #1
jayhawkhusker
Ks
None
Have a 5075m with FEL, and have to level a 60X40 foot area for a steel building. Need to move about 150 cu yards of dirt. Is this a doable project with the 5075m or should I rent something bigger vs hiring it out?
   / dirt work 5075m #2
Sounds bad, but if you know how to move dirt it will be no problem
   / dirt work 5075m #3
Dang, 150 yards of dirt for a 2400sqft pad?
Anyway, that's no problem for the 5075 and a box blade! Just yesterday I moved 14 yards of 1" crushed rock around in about 30 min with my 5075E.
GIT R DONE ;)
   / dirt work 5075m #4
Last week I moved about 50 yards with my 4520 and Gannon box blade in 1 hr 20 mins. You might need a smaller tractor for that project.JK
That is a reasonable project for your 5075M and a good box blade. Something you may need to rent if you are filling this pad in is a good vibratory roller to pack it down in 6 inch lifts..
   / dirt work 5075m
I know its a lot but the lower half of the site is about 1.5 feet below the upper half. don't have a box blade but would be willing to get one for the project. Need to move the soil about 150 feet from another area with the FEL and then use the box blade.
   / dirt work 5075m
appreciate the info, thanks
   / dirt work 5075m #7
You can use the fel to move the material quickly if you have an implement to rip up the area you are getting it from. Most of us in contracting would wan't a thick layer of engineered fill to build on too. Compaction is very important if you are pouring a slab.
   / dirt work 5075m #8
Agreed. No problem for your tractor, especially given the short distance to move the material.
Getting folks to import engineered fill around here is a tough nut to crack. I'm pretty sure most of the builders are related to the foundation repair guys and want to keep them in business!
   / dirt work 5075m #9
You do know that all the soil has to be removed from the site first? If not, the organic component of the soil will decompose and give settling problems. Especially important if you ever put hard floor like cement down.
I used a smaller tractor for a much larger space, the machine you have won't break a sweat.
If you can, let the pad area settle for a month or more before construction. Water it several times a week to help it settle. It's a lot easier to monkey with the grade before the building goes up!
   / dirt work 5075m
I haven't leveled something that require this much fill (2 feet on one side), thought that if I got major organic material (roots, plants, etc) out and compacted it every 6-12 inches I should be good. The soil I am using is really dense clay, but if I need to bring in material that's the way it goes. Any thoughts?
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
