Dipstick question
   / Dipstick question #1
gb19711
Newark, Delaware
JD110 RF, JD110 SF, JD208, Yanmar YM2210D
OK. OK. I can hear the comments already!!:D My question is ABOUT the dipstick - not from one!
I have a YM2210D which has a screw-in type oil dipstick. I know when you use the screw-in front axle dipstick that you are supposed to just shoulder the dipstick and don't thread it in to check the fluid level. Is this the case with the oil dipstick as well? Also - is the correct method to use for all screw-in type dipsticks (i.e. - hydraulic/pto fluid)?
Please advise.........
Thanks!
Greg
   / Dipstick question #2
Greg:
The manual for my YM 336D says to unscrew and rest sticks on top threads to take proper reading. Do not screw in to take accurate readings. The same holds true for all three fluid levels -- oil, front gear oil, and transmission/hydraulic oil levels.
ROLLER DOLLY (A53843)
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2007 International 4300 Dump Truck (A51691)
2007 International...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2008 International 4300 18ft Landscape Dump Truck (A51691)
2008 International...
