Dinse 10-25 Extension Cables
   / Dinse 10-25 Extension Cables #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
The cables are only about 10’ long and have Dinse 10-25 connections at the welder.
Is it acceptable to use a Dinse 10-25 extension cable on my ARC welding stick holder cable? Also could I use an extension on the ground and electrode holder?
Would it be better just to make a longer set rather than using an extension?
   / Dinse 10-25 Extension Cables #2
Extensions are fine. Been using extensions on both the electrode and ground lead for years with my Lincoln tombstone.
   / Dinse 10-25 Extension Cables #4
Another thing that I have done, make a ground cable with a magnet ground contact. Makes it nice for welding on flat or irregular shapes for close ground contact. Also have 2 different electrode holders.
Sometimes you need some length for the stinger but not the ground. Other times, you can't get what you're working on close to welder.
I have 3 extentions for the welder along with 15' stinger and ground cables. Glad to assist.
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
