Dim the dash
   / Dim the dash #1
ismilelots
Bronze Member
Beaverton, MI
LS 3135hc
I have a LS xr3135hc. I have looked through the owner's manual but can find no reference to this. Is there a way to dim the dash light? At night it's bright enough to reflect on the glass in the cab making it more difficult to see outside. Not a good thing when you're trying to stay out of the ditch while plowing snow.
   / Dim the dash #2
Probably no way to dim dash lights like a car
As a “quick fix”, maybe throw a towel over the dash; just lift it once in awhile to check temps and such.
   / Dim the dash #3
Dunno, but simple quick fix would be to lay a rag or towel over it. Move it if you need to check a gauge or reading.
   / Dim the dash #5
Is it LED? If it's incandescent, you could find the circuit and install a cheap DC to DC converter with variable output on E-Bay. LED, I'm not sure about how they are driven.
   / Dim the dash #6
Perhaps apply some 'press on' window tinting?
Bought at an auto-supply shop and cut to fit as required.
   / Dim the dash #7
You could simply make a sun-shade over the instrument panel to stop the "up" reflection.
   / Dim the dash #8
Big hammer. The more you use it the dimmer it will get. :)
   / Dim the dash #9
you could use a rheostat to dim the lights, just like cars use. you'd have to drill a hole for the control though..
   / Dim the dash #10
Isn't it possible there is a VR if LEDS are used nd it will just try and correct the low voltage?
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
MESSAGE BOARD W/ LETTERS (A51244)
MESSAGE BOARD W/...
Livestock Oiler (A50515)
Livestock Oiler...
