DIGIT 198T
/ DIGIT 198T #1
bwmarks
IL
Digit 198T
I have a 1982 Digit Model 198T that will not drive forward or backward unless you jam on the brake - it moves slowly. Now rolls freely if pushed and all other hydraulics are working fine. Any ideas?
/ DIGIT 198T #2
Wish I could help you. I have no idea if your machine has a hydrostat trans or simply independent wheel motors like my model 258 backhoe? I would say that if it has a hyro trans, you may have an issue with the swash plate. Slamming on the brakes ( I ASSUME) would put the swash plate in a neutral position, the forward/reverse would tilt the plate in varying degrees of opposing angles for chosen motion ( F or R) and speed. If you ar saying that was once the problem and now it only rolls freely ( like in neutral )..maybe it's a relif valve stuck open?
Heartland Construction Equipment Dig It Parts - HEARTLAND CONSTRUCTION EQUIPMENT is the only parts supplier / Dig-it support I Know of. I would contact them and ask some questions and order a service manual.
Single Cedar Glider (A65583)
Single Cedar...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
213085 (A64276)
213085 (A64276)
