Digging with the blade in the front or rear?
   / Digging with the blade in the front or rear? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
What's the generally accepted technique for excavating with the smaller track-hoes? Blade in front or rear? (Personal preference...)
Thanks.
AKfish
   / Digging with the blade in the front or rear? #2
Blade in front and down. Makes the machine 10 times more stable.
   / Digging with the blade in the front or rear? #3
Ya what he said, at the front,
also when you have it at the front and its down, you can lift more heavy debris without a greater chance of it tipping.
   / Digging with the blade in the front or rear? #4
Blade in front always.............do you know how much the drive motors cost!!! Huge. Beside, like evryone else said, the stability is night and day. The only time I dig in the "rear" is when on a hill and I keep the blade in back of me to jack the cab till its level. I did have rock come back and dent my cab panel once, the blade would have stopped it, and now I kep that in mind and use a 2X12 or a pile of dirt to protect my drive motors and machine from rolling object such as rocks.
Well... I thought I'd ask and throw it out there..
That's the way I've always "done it", too. But, I've seen other guys dig with the blade down and in the back.
Did notice, too... that if you're not payin' close attention to where that blade corner is located and you swing around fast enough with a tree or root wad - you can get VERY close to it with the teeth of the bucket!! :eek:
The blade in back does give you that little bit of extra clearance!
Thanks for the feedback.
AKfish
   / Digging with the blade in the front or rear? #6
Try banging your drive motors all the time, filling them with dirt, extra friction.....maybe even a bad bite with your own bucket or self propelled rock? Its a could be bummer.
   / Digging with the blade in the front or rear? #7
The only time I want the blade in the front is if I'm lifting something heavy. Otherwise I don't care if it's in front or in the back. The blade is always up anyways unless lifting something heavy.
   / Digging with the blade in the front or rear? #8
Is that with a ZTS machine also?
Most of my experience is on ZTS's, and there is definitely a difference where the blade is and whether it's up or down...
   / Digging with the blade in the front or rear? #9
I have yet to find myself in the need of a ZTS mini so my above comment is reference a conventional mini (KX121-3's, KX161-3's). I guess you can consider them more RTS. I have also not had the need to use a RTS 12 ton size excavator but I'm sure that time is coming real quick.
The only Kubota I've ever operated was 7-8 years ago. It was a ??41-?? something.. a real heavy-weight! :D
I was looking for/hoping for a blade on BOTH the front and the back!! ;)
AKfish
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
