Digging small cluster stumps with a PHD
   / Digging small cluster stumps with a PHD #1
Timber
Veteran Member
East Bridgewater Massachusetts
Kubota B7800
I had cleared an area last fall that had some pretty mature something. They had cluster stalks 3 to 4 inches in diameter. I had to gut them with a chainsaw and push back the brush to burn. well I just picked up my box-blade today an wanted to play a bit but I had about 2 dozen cluster stumps to remove 1st. I had the PHD on the tractor from last weekend so I backed up to the cluster stumps and punched 3 to 5 holes around the cluster. Then I turned the tractor around an popped them out with no problem. My PHD is my favorite implement still to this day.
   / Digging small cluster stumps with a PHD #2
What a good idea.
I never thought of that. Stumps are usually tough without a back hoe.
Know any other stump tricks?
   / Digging small cluster stumps with a PHD #3
What diameter bit did you use to drill the stumps, and what model is your Landpride auger? I'm getting ready to buy a phd, trying to decide which one to get. Some people have real heavy duty ones and others seem to have good luck with the basic models. I wouldn't be using it all that often, but would want it to be rugged enough for a 12" bit and not have to worry about overdoing it.
I use a PHD-15 but match it up to your tractor though. I am using a 9 inch auger but a 12 is good too
   / Digging small cluster stumps with a PHD #5
Good idea Charlie,
Anytime you can remove a lot of dirt around the roots makes it a lot easier to pop them out. Did you have any trouble with the auger getting hung up on roots at all?
You know it was kind of funny, the only reason it occurred to me was I had it on the tractor the weekend before to dig my sonna tubes for the deck. I went out to dig the stumps and almost took it off to put ballast on. Thats when it hit me. I had an epiphany. I couldn't believe how well it worked. I didn't really have any problem with roots. If it caught 1 I just moved it over a little. It actually cut all the smaller ones. It was pretty quick too. took longer to turn the tractor around. I didn't have to But I am a firm believer in getting of the tractor and Hitting it with a Mattock if need be, The root that is
   / Digging small cluster stumps with a PHD #7
Just be aware with this epiphany that you may have to spend 30 minutes with a large pipe wrench / cheater bar to unscrew the auger after it finds a tough root. I've seen them screw down around a root and pull the front wheels off the ground. It's a real B--- to un-fubar from that situation!
   / Digging small cluster stumps with a PHD #8
I've only had it happen twice so far. I'm not sure if hung up on a rock or root but, left it hooked up and disengaged the pto. Only about one full turn with the wrench and the 3pt lifted it right out.
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
