Differential lock
   / Differential lock #1
TVZ
Bronze Member
MF 1726E
I can't figure out how to lock the differential on my MF 1726E. The control by my right foot is sort of an upside-down capital "L", and I'm not sure if I'm supposed to move the lever down or to the side. Even by stepping on it, I can't seem to engage it by moving the lever down; but I also can't move it sideways. Can anybody clue me in here? Thnx...
   / Differential lock #2
I tried finding info but could only find a review saying you use your right heel. Normally, on other tractors, you put your heel on it and you feel it click in once the holes line up. Just try it. Drive slowly in a tight circle, push down with your heel, feel for it to engage. Once it does, it will start skidding one of the rear tires when driving in a tight circle. To unlock, let off your heel and back up to release the pressure on the mechanism and it pop out.
   / Differential lock #3
I push down with my right heel - about 25-30 pounds - you can feel it click and engage. When it engages the lever and your heel will drop down to the floor. Get your heel off the lever - it will click up and disengage. I don't remember ever having to back up to disengage. Of course, I've never driven in tight circles with the diffy lock engaged.
   / Differential lock #4
The tight circle thing was just for a quick test. (easier than finding a bunch of mud to play in)
   / Differential lock #5
You got a point there ruffdog.
   / Differential lock #6
Do you need to have 4-wheel drive engaged for diff lock to work?
   / Differential lock #7
On my tractor the diffy lock works in 2WD and/or 4WD. I would expect most 4WD tractors are that way. My lock works on the rear diffy only.
   / Differential lock #9
My 1705 I just put my toe on it and apply slight pressure and it should drop in if not just leave your foot on it and try going in reverse it only locks the rear axle and has nothing to do with the front drive. To release it just take your foot off it and it will release do to spring pressure I use mine when I mow my neighbors back field which doesn't matter if it spins I have AG tires on mine which are the best tires for me. I do alot of dirt work in soft conditions being self cleaning I don't get a lot of mud build up in my tread and the diff lock has saved me many many times from getting stuck.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
