differential lock
   / differential lock #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
How the heck is one supposed to toe the gas pedal and heel the differential lock at the same time. I wear size 12's and it's a struggle. Thinking of extending the diff. lock pedal.
   / differential lock #2
What model machine???
   / differential lock #3
Most tractor operations use the hand throttle at a prescribed amount of revs to ensure the juices flow or PTO spins, even things like using the loader. So in theory you should have elevated revs already, just a matter of heel and clutch. Now on the hydrostatic tractors I dunno.
Perhaps a second hand pair of Ronald McDonalds shoes :)
   / differential lock
I'm sorry, ck35 gear drive.
   / differential lock #5
I have never used my foot throttle I set hand throttle and leave at same rpm unless I need to speak to someone or get a cold drink.
   / differential lock #6
Some of the old tractors had a lever extended from the pedal so you could also use your hand if need be. It wouldn't be too hard to fabricate this feature on to your tractor. Using the hand throttle as others have said is a good option but, sometimes a certain situation might make a free hand a better choice...Mike.
   / differential lock #7
As said just use the existing hand throttle. Also please don't forget you can use split (steering) brakes to brake the spinning wheel slightly, and this will put more torque to the stationary wheel with better traction. Again use your hand throttle to set engine speed. In some ways this can be more effective than diff lock, as you can switch back and forth to "crab" the tractor sideways a bit to get a better bite.. For instance if say right rear tire is spinning and it is on the downhill side, crank front wheels right, to point downhill, press right steering brake (make sure they are not locked together), and the left rear will "screw" the tractor clockwise and point the front end downhill and often get you unstuck. Brake steering can also be handy on snow and ice when the front wheels have very little traction to steer the tractor, you can press "right or left rudder" to keep your nose pointed in the direction you wish to go. Good luck.
   / differential lock #8
I also use my split brakes a lot, mostly for steering in the snow. Had not thought it use when stuck, good idea.
Joel
   / differential lock #9
You need not HOLD the diff lock pedal to keep it engaged, Just press it once while letting out the clutch. The locking pin won't pull out until traction is released (over run) or the brakes are applied.
At least that is how "some" split diffs work.
   / differential lock #10
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
2016 Chevrolet Impala Limited (A50120)
2016 Chevrolet...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
2011 Isuzu NPR 16ft Box Truck (A50323)
2011 Isuzu NPR...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
Rhino MD-84 (A50121)
