Differential lock pedal stuck
   / Differential lock pedal stuck #1
KeithT
West Virginia
Kioti CK3510HST SE
I am unable to engage the differential lock on my YM 1300D. Even standing on the pedal while moving it will not engage. Any suggestions on what may be causing this/ and how to fix?
Also, is it possible to mount a 3 pt logsplitter using this tractors hydraulics, or am better off with a PTO pump?
Thank you in advance for your help. -Keith
   / Differential lock pedal stuck #2
I wouldn't stand on your pedal or try and force it you may break somjething. To engage my diff lock it has to be in situation where one or both of my wheels are slipping on my 2wd tractor and when I do engage diff lock it doesn't take much pressure. I assume it works the same with 4wd. I did have a problem when I didn't remove some ice buildup under the pedal though. You may have to disassemble it to find out what is wrong if everything appears ok externally.
   / Differential lock pedal stuck #3
Have you checked the obvious, is the lever frozen from rust where it enters the differential housing, (PB Blaster)?
   / Differential lock pedal stuck #4
I agree with both of the above posts. We find them stuck sometimes. PB Blaster and some patience normally works.
The hydraulic pump is too low of GPM to operate the splitter at an acceptible speed. Splitters normally use a large ram, that equates to volume of fluid. You would have to have more patience than I do to be happy using the tractor pump.
Where the rod goes into the housing for the diff lock is corroded. I can see ther was a rubber boot that is dry rotted. I sprayed WD40 on it. I will try some other type of penetrating spray. If I take off the three bolts where the diff lock rod enters the case, what should I expect? Will I get in over my head?
I guess I will look for a PTO pump type logsplitter.
Thank you, -Keith
The PB Blaster worked!! Thanks for the help. -Keith
Hustler Raptor SD Zero Turn Mower (A51573)
Hustler Raptor SD...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53472)
John Deere 1110...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
LOT LOCATIONS (A52577)
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
