Differential Lock on F Series
   / Differential Lock on F Series #1
stickboy
Idaho
FB15D
Is the diff lock supposed to pop out if you don't hold it in with your foot? My pops out immediately if you don't step on it. I have a F15D and occasionally I use the diff lock on slimy hills.
Thanks.
   / Differential Lock on F Series #2
Stickboy:
I'm not sure on yours but I'm betting that yes it does pop back out when you take your foot of of it. On my little yanny it's spring loaded and only stays ingaged with foot pressure or if I remove my foot it will pop out when both tires have good traction.
Whiskey
   / Differential Lock on F Series #3
That is correct. It is spring loaded to uncouple when the load is balanced. While one side has better traction than the other it will stay connected.
   / Differential Lock on F Series #4
My FX24D pops out when my foot is not on it. BTW diff lock is great for snow & as you learned on hills.
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
