Tires Different size tires
   / Different size tires #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
I just got my new B7510 with bar turfs. When I got it, the dealer had to order me a new front tire as the two fronts that came did not match. The molds were different so thatvone tire was more "flat-treaded" and slightly smaller in diameter that the ones I'd ordered. So, the new tire came, same tread, same profile, but it is about one-half inch taller. Will this make enough difference in the front axle gearing to damage it over time? I could see if BOTH fronts were the same size, and a little larger than they weres upposed to be, but with one front larger than the other, will I wind up with overwind in the gearcase?
   / Different size tires #2
The two tires should be a direct match to each other and be the proper size to maintain the relationship between the front and rear tires. I would suggest to the dealer that he order 2 matching tires from the factory, or take two matching tires off of another machine in the yard. There is no reason to accept a new machine with mis matched sneakers. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
3 PT DIRT SCOOP (A51243)
3 PT DIRT SCOOP...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Woods Brushbull 720 3 pt Mower (A50514)
Woods Brushbull...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
