DIfferences in Mower Blade Types - Recommendations for 84" Grooming Mower
   / DIfferences in Mower Blade Types - Recommendations for 84" Grooming Mower #1
B350driver
Navasota Texas
John Deere 4066R
Can anyone briefly explain the difference in the types of mower blades. I did attempt to research but could not find any comparisons, only personal preferences. I am running a Frontier GM2084 - 84" Grooming mower with a JD 4066R tractor. I have around 5 acres that will be routinely mowed. I want to buy a replacement set, but my owner's manual list 5 choices:
Standard Blade
Mulching Blade
High Lift Blade
Flat Blade
Gator Blades
Thanks in advance for any information/suggestions!
   / DIfferences in Mower Blade Types - Recommendations for 84" Grooming Mower #2
From my experience:
Standard blade: medium lift blade, low wings on the ends of the blade
Mulching blade: low lift blade with longer cutting edge at differing heights along the blade. You can use a deck plate to cover the discharge chute to not allow the grass to leave the deck, and it continues to get cut up into smaller pieces.
High Lift blade: taller wings on the ends of the blade. Helps if grass is wet or has high moisture content. Discharges grass a good distance and spreads well
Flat Blade: as you would expect, no wings on the end, low lift.
Gator Blade: a high lift blade with a high wing on the end. Wing is segmented so it has multiple cutting edges to cut the grass multiple times before it is blown out of the deck. You can use a deck plate to cover the discharge chute to not allow the grass to leave the deck, and it continues to get cut up into smaller pieces.
I use high lift blades on my mower during spring and early summer when grass has more moisture. Gator blades and mulching blades can clog up the deck my cutting the grass until it becomes soupy under the deck. Then I switch to gator blades during late summer and fall. They do an awesome job on leaves - I live in New England so we get a lot of leaves. A few passes of the gator blades with a chute plate and there is nothing left of the leaves. Instant mulch!
If your field is dry and dusty, you don't want high lift blades. You would want flat or low lift blades to keep the dust down.
Great information, thank you so much!
   / DIfferences in Mower Blade Types - Recommendations for 84" Grooming Mower #4
My experiences are similar to Boylerman's. I swap between high lift and Gator G6 on my 72" Woods RFM. Gators pack-up too much under the deck in the spring when the grass is lush and growing fast, so I use the high lifts. From mid summer through the end of the season, I love the way the Gators chop up the clippings.
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
LANESHARK LS2 LOT IDENTIFIER 146 (A53084)
LANESHARK LS2 LOT...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
KMC 5610 LOT IDENTIFIER 33 (A53084)
KMC 5610 LOT...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
