Differences between a D1300FD and a MT372D
   / Differences between a D1300FD and a MT372D #1
bhood3
BC Canada
Mitsubishi MT372D/ International 2444
I currently own an MT372D that needs an engine along with other things. I came across a D1300FD for sale at a good price and although I know they share the same engine but was wondering if anyone knows what other components would be interchangeable? Thanks!
   / Differences between a D1300FD and a MT372D #2
Do both have the KE130 engine then? The Satoh S630 Bull has the KE130-13B engine. This is a direct OE import to North America. So, look for one of those too. ;)
I have added the only manual I got on the S630 Bull.
  • SATOH BULL S630 INSTRUCTION BOOK.pdf
These tractors have the KE70 2 cyl diesel in them, but thanks for the info. I did buy the tractor, looks awesome in the pictures, supposedly has very low hours on it. The guy bought it without attachments and realized afterwards that the hitch and pto splines are not standard so all he used it for was towing an orchard sprayer around. Pick it up Wednesday, about 400 kms round trip. I will mount the loader off the MT372D on the new tractor and will make use of my cultivator and rear weights as well. So, will have a MT372D available for any parts needed, including has good ag tires all around, excellent trans and transaxle, front drive axle works well but has a couple of leaks, needs hub seals, steering box has all new bearings in it, engine needs tlc, valve guides and rings to start with. Let me know what you need, Thanks.
   / Differences between a D1300FD and a MT372D #4
Ah, I have a few of the KE70 manuals. :)
I was once a moderator over on the Yahoo Groups Mitsubishi-Satoh that has moved to GroupsIO. Between BubbaGoat and myself, we rescued many of the manuals from being totally lost.
main groups.io Group
As I'm now the owner of the Yanmar Tractor Owners Group, it takes more of my time. But, I do poke around the Mitsubishi forums some. ;)
Oh my, I did have the MT372 KE70 Engine Service Manual. (y)
So, these manuals could prove to be useful to know what parts would swap.
  • MITSUBISHI ENGINE KE70 KE75 PARTS LIST.pdf
  • MITSUBISHI ENGINE K2AS K2B K2C KE70 KE75 SERVICE MANUAL.pdf
  • MITSUBISHI MT372 KE70 REPAIR MANUAL.pdf
That's great! Thank You for the manuals!(y)(y):)
   / Differences between a D1300FD and a MT372D #6
We posted about 50 manuals on the tractorforum.com Resource Manager sub-forum for just Mitsubishi-Satoh. We made mention of it in the Mitsubishi GroupsIO community.
This way anyone can get their machine back up and running sooner. :)
Valley Power is the largest contributor and largest support for parts and hard to find items.
Just for future reference the MT372D and the D1300FD tractors are virtually identical for components except the front drive axles are different and the hood and front grille are a little different, but everything else is the same. Also The Satoh Beaver S370 and S370D are same.
   / Differences between a D1300FD and a MT372D #8
S370 = 2WD
S370D = 4WD
Yes, I should have clarified the drive setup, what I was trying to point out is the commonality between components
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
