Difference in m6040 and m7040?
   / Difference in m6040 and m7040? #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
Looks like both are built on same chassis and have same engine. The 6040 has about 64hp and m7040 about 71hp. Anyone know the difference is that adds the extra few hp?
Setting on injection pump or slightly larger injectors?
   / Difference in m6040 and m7040? #3
I suspect there are other differences like injection timing, fuel amounts metered electronically and controlled by the microprocessor chips. Those are the differences between my MF 2660 and the 2670 and 2680. Appears at first glance to only be HP. Same block, same model engine. However, the 2650 and 2660 share a slightly shorter frame while the longer framed 2670 snd 80 also have features like external hyd cyl for 3pt lift, etc. You may have those kinds of differences between 6040 and 7040, I don't know.
   / Difference in m6040 and m7040? #4
Check the Hyd pump flows, or power steering flows… one machine may be more/less than the other? The 8 speed vs 12 speed transmission may change that also…..
   / Difference in m6040 and m7040? #5
Also keep in mind that no two tractors will pto dyno the same either. What a manufacturer says it has and what it really has are usually 2 different things
Wouldn't a 2008 be all mechanical injection system?
   / Difference in m6040 and m7040? #8
7040 has limited slip ft differential, 6040 does not. same engine setup, different tuning
   / Difference in m6040 and m7040? #9
Sure about that. All the Kubota's I've seen have at least locking rear differentials, not limited slip. Mine have both front and rear lockers.
   / Difference in m6040 and m7040? #10
7040 on up to 9540 all have limited slip ft differential. all of them of course have locking rear
1997 Chevrolet S10 Ext. Cab Pickup Truck (A48081)
1997 Chevrolet S10...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
Wacker Neuson TH522 Telehandler (A50860)
Wacker Neuson...
2006 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2006 Ford F-250...
Excavator Bucket (A49461)
Excavator Bucket...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
