Difference Between Two Air Compressors
   / Difference Between Two Air Compressors #1
BillyP
Veteran Member
Eagletown, OK
JD 4610 ehydro MFWD
   / Difference Between Two Air Compressors #2
The maxtool ad says the 2430N5 replaces the TS4N5. I think its probably a newer model. Specs look similar. Price is different only because its a different company selling that has a different profit margin. Just my opinion but I'd save the $250 and go with the TSC model. You might even get a 10% dicount if you ask at the register. I've asked for a discount on large purchases at the checkout and they said "sure, I can do that"
   / Difference Between Two Air Compressors #3
from the one thats about $100 more
"Includes a FREE IR Start-Up Kit, ... a $99.00 Value"
"nothings ever free"
   / Difference Between Two Air Compressors #4
Sorry to dredge up such an old thread but I need some help on this matter also.
What is the difference between these two?
One has a vertical cylinder pump and the other has a V cylinder pump. Both are two stage 175 psi and have about the same CFM rating.
Is one better than the other?
The IR TS45N from TSC is $999.00. The best price I found on the IR 2430N5 is $1299.00. These prices are for the compressors only, no start up kits (oil) and no bells and whistles.
I have also been considering a quincy compressor the same size as the IR.
Please help me out here my current compressor is shot and I want to replce it ASAP.
   / Difference Between Two Air Compressors #5
For a personal, not necessarily scientific, opinion . . . all else being equal I'd prefer the V cylinders, primarily because I believe they will cool better and therefore lengthen the life of the compressor if it's run continuously for long periods of time. As a practical matter, for most of us, either one should last a lifetime.
   / Difference Between Two Air Compressors #6
If it's going to be in the same building with you, check the pump RPM. A friend of mine bought a huge Sears which worked great, but it ran 3000 RPM, and the noise was horrendous! He finally sold it and bought an old Quincy that chugged along at 600 RPM. Much easier on the ears!
   / Difference Between Two Air Compressors #8
Truer words never spoken!! "cheap" compressors often have to overspeed the pump to deliver the advertised CFM. A slow speed (6-700) RPM pump is much quieter and will last longer.
Dolly for Pup Trailer (A42021)
Dolly for Pup...
(2) Large Blast Mats (A42021)
(2) Large Blast...
2023 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A42744)
2023 Chevrolet...
Utility Trailer (A42742)
Utility Trailer...
New/Unused 72inch Greatbear Rock Bucket (A44391)
New/Unused 72inch...
2008 WESTERN STAR  4900EX (A45046)
2008 WESTERN STAR...
