Difference between t1855 and ta043 cab filters
   / Difference between t1855 and ta043 cab filters #1
Hersheyfarm
Veteran Member
NE ky
They are basically interchangeable and both end in 71600. The tao43 is better built and has 2 red lines running the length, and cost about $20 more. The t1855 has thicker looking element and cheaper gasket. Any information on the difference? Both are kubota brand factory filters.
   / Difference between t1855 and ta043 cab filters #2
Impossible to know without knowing the design specification for each and I never seen these published. Considering they fit the same applications, they must meet Kubota's minimum requirements, so I would buy the lower cost one. In either case the cost is a bit high considering these are only filtering cabin air.
Too bad the more expensive one isn't a HEPA filter or something that might benefit the operator.
Hope someone can provide the details you're looking for.
There is slight visual difference in media material. As far as hepa I think it would be too restrictive for our hvac systems.
   / Difference between t1855 and ta043 cab filters #4
100% correct. The HEPA would be a hepa junk in about a day in the field. In fact I find the entire HEPA thing to be mostly advertising hype. Kubota offers a spray grade charcoal filter but it's not a cheap date.
2015 Ford F-450 Service Truck (A51692)
2015 Ford F-450...
2016 John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
2016 John Deere...
378748 (A51573)
378748 (A51573)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
