Difference Between JD 4044R & 4044M ??
   / Difference Between JD 4044R & 4044M ?? #1
bigcut
SC PA
Garden Tractor
I compared some of the specs info on the JD 4044R and 4044M. The only difference I could find is the M doesn't allow the option of the cab. Other than that, they appear identical except for the $3K higher base price for the R. I'm a little puzzled. What am I missing ?? Can one of you JD experts enlighten me ?
John
   / Difference Between JD 4044R & 4044M ?? #3
John
Looked at both today in conyers. The r has a different trams than the m. The r you can get off the tractor and move it forward and backward using a button on the back, also raise and lower the 3pt arms up and down when hooking up implements. There is also a switch that allows the engine rpms to idle then go up when you start to move, like a cars auto trans. Better cruise also. Other small perks as well. I was quoted 34300 for a 4044r with fel and rear remotes. Don't know if thats good but its what I was told. I would say the r is similar to kubotas grand series.
   / Difference Between JD 4044R & 4044M ?? #4
I was researching the same thing a few months back and I found one fact that was staggering between the two. The downside is, I don't remember it!
I don't think the 4M series can be had with the 3PT down-force kit that gives you hydraulic down pressure on implements. Also, the loader joystick on the 4M is positioned in a weird spot up on the right hand side of a steel plate. On the 4R series, it is in a much better location for the operator, coming out of the floor by the right side fender. There are other differences, but most of them minor. Each person will feel differently about this, but for myself, if I was going to spend $30,000 on a 4M, and a 4R was only $4,000 more, I would spend $34,000. An extra 10% or so isn't that bad.
You can get a 4052M for the same price as a 3046R. I would take the 4M over the 3R when money is equal. You get a much larger machine with way more capacity, and substantially more engine. One major downside to the new 3R and 4R machines is the pricing. John Deere really upped their cost on these because of the new emissions equipment needed to get the diesels to meet Tier4 standards. Naturally, John Deere passes this onto the consumer, even though they could have EASILY absorbed that cost, and still made boat loads of cash.
I honestly believe that on a $40,000 tractor, there is probably $15,000 - $20,000 total profit in there. I have been involved in business in the last two years and the standard amongst companies seems to be around 50% return in profit, as far as retail type stuff goes. IMO, that should not be allowed. That is down right stealing from us hard working average guys!
   / Difference Between JD 4044R & 4044M ?? #5
John
Shane here with Mutton Power. Couple things. The R comes with the following standard. M does not
3pt fender control
Fender control foward and backup
Swivel seat (open station)
High back scissor suspension seat
H180 loader option (M has D170 fixed loader option only)
Hope this helps. Pm me for a quote. Thanks
   / Difference Between JD 4044R & 4044M ?? #6
Shane
How much for a 4044r and loader?
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
JLG 1255 Telehandler (A52748)
JLG 1255...
KUBOTA ZD1211 (A53084)
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
