Difference between D and DA on TC models?
   / Difference between D and DA on TC models? #1
LowerSlower
Georgetown, DE
TC35DA
Hey guys, its probably in a thread, but my search didn't lead me to it. Anyway, a real easy question here for most, but not for me, cause I bought my tractor used from a Deere dealer. What is the difference between the D and DA in the TC series? Is it a transmission thing or something else. My guess is the hi/lo switch on the loader controller? Just curious.:D
   / Difference between D and DA on TC models? #2
I am curious as well. Have dug into it a little bit with no luck, but nothing I would call an extensive search yet. Let me know if you find out (will do the same).
   / Difference between D and DA on TC models? #3
I have a TC25D and if memory serves me right, the 'D' got you the following on Class II Boomers. The Class IIIs might have been different.
- HST
- Folding ROPS
- Adjustable (for weight) seat with swivel.
- Tilt and telescope steering wheel
- Tool box
- Different instrument panel (I think)
- Deluxe 3ph linkage
   / Difference between D and DA on TC models? #4
The "D" stands for "Deluxe," and the "DA" stands for "Darn Awful" lights.:laughing::laughing::laughing:
Actually, the "DA" stands for "Deluxe" with "Advanced" features, I believe. The DA model tractors were a major styling change that included the new lights and changed hood. It also had some changes to the electrical circuits with a new controller/timer for the glow plugs and a change to some relays. The rear lights were moved from on top of the fenders to mounted on the ROPS. Also, the handrails were redesigned and moved to the tops of the fenders, and the operator seat was changed slightly in color and style. The battery was changed so it didn't outgas into the radiator like the old one. The HST models have a bigger return spring to help prevent the sticking pedal problem. There are also some changes to the instrument panel and some of the switches for turn signals were changed.
There might be some more minor changes I've missed, but I don't think there are any major changes to the internal powertrain or any of the hydraulics. The rabbit/turtle function on the joystick has been around since the "D" models were introduced. My "D" model tractor has that and I love it.:) Oh yes, speaking of joysticks. I have a very long thread called "No Joy Joystick" that chronicles the sorry design of the early joysticks. With the DA models, New Holland improved on the joystick mounting design and eliminated the problem. I've retrofitted my tractor with the new part and it works great.:thumbsup:
EDIT: Reading MikePA's post made me realize my comments were slanted toward the Class III tractors. The Class II tractors don't have the rabbit/turtle function.
Also, the gear model tractors just used to be "TC" and a number. After the styling changes, they changed to add the "A" on the end. For example, the TC40 became the TC40A. Like the deluxe models, I think this change came about with the 2004 year model tractors.
   / Difference between D and DA on TC models? #5
So right Jinman! I just about hate the lights on my TC48. I think they are completely over the top, and unnecessary. Terribly expensive if you break one also. Massey, and other brands have done a much better job, for much less money. I'd rather have just the "D" style. About the only fault I can find so far with my machine. Doesn't have to be aerodynamic.....it's a tractor. Also miss the additional clearance with the rear fenders with the older sheetmetal fenders of the 1920, 2120 NHs.
   / Difference between D and DA on TC models? #6
I checked your profile and see you have a TC35, which is a Class III, so jinman's post would apply to you.
   / Difference between D and DA on TC models? #7
Thanks, jinman! The way they do the models is starting to make more sense to me now. I was getting hung up on the automotive paradigm, since the model year seems to be commonly listed when you look at dealer ads.
From your description, it sounds like feature changes go with the model numbers and the year makes no real difference.
Thanks again!
   / Difference between D and DA on TC models? #8
Just think how confused people will be in about 5 or 6 years when they see TC40, TC40A, TC40D, TC40DA, T2310, and Boomer 3040. When somebody asks the question in the future, I'll just tell them that the old number is a tractor and the newer number is a tractor on drugs.;) No way am I going to try and explain the differences and why NH changed the numbers.
   / Difference between D and DA on TC models? #9
Hey jinman,
If some of the parts are interchangeable these tractors could end up in a country song, kinda like the Johnny Cash Cadillac. :laughing:
Thanks guys. I didn't realize there was a year difference between the two, I thought the A was an upgrade or something to the plain D. I never knew the details because I didn't follow the line for too long, though I now know the equivalent to the TC40DA is the 3040 and last model it was the 2010. Strange way to run similar product.
   / Difference between D and DA on TC models? #11
When first models came out; they were "d" models; when newer models came out with more features; they became DA models. So, D models are just older models. i KNOW tc "d" models started in late 1999.
   / Difference between D and DA on TC models? #12
Okay Jinman, I've just bought the TC48DA 2004 and your post helps me a great deal. My follow up question is what is the difference between the 18LA and the 16LA? My TC48DA came with the 18LA loader?
   / Difference between D and DA on TC models? #13
Bigger, stronger loader built for bigger, stronger tractors. The 16LA fits Class III non-SuperSteer New Hollands, the 18LA fits Class IV tractors.
   / Difference between D and DA on TC models? #14
To quantify what RickB said, the difference is about 350 lb more lift for the 18LA loader in real-world numbers. If you compare the lift at the loader pins, the 18LA has 500 lb more lift.
Also, the 18LA is New Hollands old number for the former manufacturer of loaders. Their new loader that compares to the 18LA would be the 270TL loader. It used to be that New Holland had the even numbered loaders for non-SS tractors and the odd-numbered ones were for SS tractors. For example, the 14LA, 16LA, 18LA were all for non-SS. The 15LA and 17LA were the same loaders for SS class II and class III tractors. Now the numbers are a bit of a mess like the tractor models. There's the 240TL that replaced the 14LA and the 240TL SS for supersteer. However, when you get to the next class up, there's the 250TL for non-supersteer and the 260TL for the SS model. If this is a bit confusing, don't worry. I have the table open in another window. That is the only reason I can post about this without too many errors.:rolleyes:
EDIT: Bear in mind also that Case/Farmall has the same loaders with yet a different set of numbers. Trying to keep all the numbers straight is like a poke in the eye with a sharp stick.:thumbdown:
   / Difference between D and DA on TC models? #15
Holy Cow! :confused:
I want you to know grateful I am that you are willing to answer these type of questions from a rookie like me!:D I only hope I can pay this forward someday. I've seen your posts to serious problems and I realize there are much bigger concerns regarding tractor ownership than what the Loader difference is -- I've got a lot to learn. Thank you again for being willing to help and share with me -- thanks.
Adam
   / Difference between D and DA on TC models? #16
Somewhere in there is a designation that indicates a hydrostatic tractor vs. shuttle-shift. Our TC40 is a shuttle, and I believe it was called a TC40A, but now I'm gonna have to go find my paperwork. Whatever it is, the hydro designation also indicated tilt steering and a couple other features, which the shuttle tractor doesn't have.
2020 DRAGON ESP...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2023 Kubota L6060HST Compact Utility Tractor (A56438)
2023 Kubota...
