Difference between a Middlebuster and plow
   / Difference between a Middlebuster and plow #1
MarkStewart
Pine Bush NY
Yanmar 1401
What's the difference between these impliments? What are the specific uses of each? Can one do the work of the other? They seem to look similar, I was wondering wich one I should get. I wanted to dig up some ground to make a small food plot for deer etc.
   / Difference between a Middlebuster and plow #2
A real plow (1 or 2 bottom) will turn the soil over.
They come in 12,14,16" or larger for farm tractors.
So 2 14" plows will turn about 28" of soil.
A middle buster just cut a V shaped trench.
If u can find a chisel plow (small one) it has multiple shanks
(similar to boxblade rippers) and breaks up soil and depending on shoes will turn some soil.
If the ground isn't real hard a field cultivator (like a chisel plow but lighter duty) will break the soil up.
If u have a boxblade put the rippers all the way down and shorten toplink (don't put blade on ground), this will tear up soil too.
A chisel plow or field cultivator will leave residue on top to help mulch and reduce erosion.
Then take a disc or tiller over it for finishing before seeding.
U could drag it if u want to level the area.
   / Difference between a Middlebuster and plow #3
Mark,
I was wondering when this question would come up. Like Hoeman says, a MB just cuts a V shaped trench, whereas a plow (sort of like the left or right half of a MB) actually turns the ground over. You probably won't see farmers using a row of giant middle busters to prepare their fields for planting, but for your use (and mine), a MB might do just fine.
A plow turns the earth one direction and can put some side pressure on the back of your tractor. That could make it hard to drive straight, though I don't know if that would be a problem or not.
I think Hoeman's explanations are excellent. As he indicates, there is more than one way to go. A middle buster may not be designed specifically for garden prep, but that is what I use it for and I am satisfied with what it does in that capacity.
OkieG
   / Difference between a Middlebuster and plow #4
My thinking is that the middlebuster is what the farmers used a lot in the horse & buggy days (before multi cropping), to lay the land by in the fall for the next season. By using a middle buster, you only had to turn 1/2 or less of the land & yet covered all the growth. It also set the field up in rows of hills & valleys,which helped contain moisture. In the spring, you could plow out the rows of hills & plant the seed behind, in what was now nearly level ground & all unwanted vegetation was covered again at the time of planting.
Also we used these to plow our potatoes & peanuts out of the ground when harvesting, or dig shallow ditches.
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A53426)
2014 HINO 338 26FT...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
