Difference between 4WD and MFWD
/ Difference between 4WD and MFWD #41
N80 said:
Thank you. That has been my sole contention in all of these 4wd posts.
I agree. And to clarify, when I discussed how my tractor operated my only point in that matter was that you cannot _feel_ the binding in my L4400 even in a tight turn. It was someone else who suggested that my tractor was 'special'. I was quick to point out that the L4400 might be the least 'special' tractor that Kubota makes. :p
I think if you read above we agreed that we wouldn't use the word special. We decided that a MFWD tractor that didn't bind going straight or while turning was fictitious. :)
/ Difference between 4WD and MFWD #42
ovrszd said:
I don't know if we should pay any attention to you Soundguy!!! I saw your list in the Roll Call thread. You definitely have an addiction problem!!!! Hahahaha!!! :D
Don't be hating on them old fords.. they are like timex watches.. the keep on ticking...
Those old guys still earn their keep. The 8n used to be semi-retired and now actually is back on mower duty with a 5' mower, and also on seed and fertalizer spreader duty. The 660 is the only tractor I have with a loader.. so it's uses are obvious. The 5000 and 7610s are oversized lawn mowers...
Soundguy
/ Difference between 4WD and MFWD #43
My B-I-L just recently dragged his old Ferguson out of the barn and got it running so that one of his girls can pull an extra hay rake with it. Wasn't it a Ford precursor?
/ Difference between 4WD and MFWD #44
Harry was into tractors before he got up with Henry.. however it was after the handshake deal went south, and then the lawsuit, before harry started his line of fergy tractor.. ironically, using ford drawing that had been obtained during the partnership days.. I.E. the 9N came out way before the T?20
Soundguy
/ Difference between 4WD and MFWD #45
My old 48 Ferguson TE20 never needed 4wd/MFWD, if the rear wheels started to spin I just raised the plow a hair higher :D
It was a great tractor and worked very well for being 50+ yrs old.
To add to the above mentioned Ford/Ferguson partnership Ford-Ferguson Tractors during the 1940s
OK guys, time to go back to the original question - is there a material difference between 4WD and MFWD? I always thought they were different manufacturers' terms for the same thing, but the Goodyear farm tire guide identifies them as two different categories with materially different tire sizing guidelines. This Goodyear material suggests there is a difference between the two and that the terms are widely understood in the industry (they offer no explaination of what the terms mean).
The only thing I've heard so far that *might* answer the question, is that 4WD indicates/implies same-size tires front and rear, where MFWD indicates/implies different-sized front and rear tires.
Any other ideas? So far my conclusion is that our collective answer is "we don't know".
/ Difference between 4WD and MFWD #47
I have nothing concrete to base my interpretation on, but then it's probably as sound as listening to a tire manufacturer's interpretation. At least I'm not trying to sell anything.
4WD describes a tractor that is providing power to the front and rear axle at all times.
MFWD describes a tractor that can be operated in rear wheel drive only and engages the front axle by mechanical action at the operators discretion.
/ Difference between 4WD and MFWD #48
machmeter62 said:
I have a Kubota L295DT I purchased nearly 30 years ago new, and has rarely been out of 4WD! The operators manual makes no issues about using it in 4WD. The parts manual shows a differential between the front and rear axle; therefore, where is the stress? Is it wearing out the differential? It still works as advertised! Weight wise, it has always had a loader and backhoe on it, and all four wheels filled with liquids. There is no whining in the drive train either? Maybe, it's a fuel mileage thing? It is called DUAL TRACTION and 4WD only, but I assume it falls under the manual type, since a lever is required to engage it? The total weight with the wheel fluids, backhoe, and loader, increased the basic tractor wt. from 2600# to 5000#+. If I had to stop and change the 4WD lever everytime I was on a hard surface, the lever would be worn out! I also checked with various Kubota rental yards over the years, and they said, "leave it in 4WD."
If the manufacturer wanted a rig to stay in 4WD they wouldn't have spent the extra money for the linkage and lever to take it out of 4WD. Think about it. Kinda like putting seat belts in cars, they expect that you'll use them even though some folks don't.
In the case of New Holland's SensiTrak in a turn 4WD is automatically disengaged so the the front wheels can turn free at different speeds and not put undue stress on the drive line gearing. Naturally this system can be locked out, but I have never felt the need to do so.
/ Difference between 4WD and MFWD #49
Again, I think the problem is that there is no technical concensus on this terminology. We've heard a wide variety of possibilites, and some very rational suggestions. But as long as the manufacturers use their own proprietary terms to describe a wide variety of systems, then it is going to be hard to reach agreement on concrete, specific terms.
As mentioned, Kubota uses the term four wheel drive or 4wd almost universally on all of their tractors. My Kubota has a big silver "4WD" sticker on both fenders.
/ Difference between 4WD and MFWD #50
Soundguy
"Loosly" based on old wives tales found mostly on Ford collectors sites.....
Actually, Ferguson developed his first tractor with the "FEGUSON SYSTEM" in the early 1920's. Known as the "Black" tractor, it was the test bed for the 3-point hitch and draft control system.
Later on, in 1937 or 38, Ferguson started building the Ferguson-Brown tractor until he and HEnry Ford partnered on the N series bringing Ford back into the tractor world which he had left some years earlier. After it became apparent Ford wasn't looking out for anyones interest but his own, Ferguson started marketing a tractor that was ALREADY IN EXISTANCE, built by the STandard Motor Company. It used The Ferguson System which Harry Ferguson owned the patents.. That tractor was badged as the TE-20. It WASN'T in any shape or form "Using drawings that had been obtained in the partnership days".
/ Difference between 4WD and MFWD #51
Re-read my post and the question above it word for word. The poster asked if the 'ferguson' was a precursor to ford... he didn't mention any of the other specific tractor that harry had his hands in... The ferguson tractor.. I.E. the t?-20 was not a ford precursor. The ford 9n came out in 39. the fact that harry had his hands into other tractors previous to that does not change the fact that the 'ferguson' t?20 was NOT a ford 9n precursor. hard to be a precursor when you are built 9 or so years later..
Soundguy
/ Difference between 4WD and MFWD #52
Soundguy
Hre we go again...
Where on EARTH do you see where I said the on TE-20 was on the market before N series? You won't find that because I flat DID NOT say that.
and the part about the TE-20 being drawings taken from Ford during the partnership days..... Some story...... The TE-20 was a tractor built by the Standard Motor Co. No connection with Ford. Already in business..... Add the Ferguson System that Harry Ferguson OWNED patents on. The weren't Ford property. Judge said so.....
Ferguson BLACK TRACTOR, and Ferguson-Brown tractors BUILT WELL BEFORE N-series were equipped with virtua;lly the same EXACT Ferguson system that ended up on N Fords. All the real proof that was needed of Fergusons claim of ownership of his design. Judge said so.....
/ Difference between 4WD and MFWD #53
My fault on that last post. i ran 2 replies together. The part about the precursor, etc.. was meant to be adressed to N80.
Soundguy
/ Difference between 4WD and MFWD #54
I believe the reason kubota uses the system that it does is because of added ground clearance. The Hummer H1 and Mercedes Unimog also use gear reduction hubs for this purpose. This system reduces driveline stress and places it out at the wheel instead of the inner differential. As a side note, the load on the front drive on smaller Kubotas must not be too great as the size of the front drive shaft is pretty small. Yet I've never heard of a failure of this component on the B series. I've had the front axle apart on my B2400 and the differential inside the axle housing looks pretty small,but it's a rock solid piece of equipment! The only front end failure I've had is the lousy little $1.60 O-ring that goes between the axle pivot and bi-speed unit. 7.5 hrs the first time, 4hrs the second ( learned a few short cuts!).
/ Difference between 4WD and MFWD #55
Friends
I think this explination may help. Or it may complicate things. :confused:
The concept of front-wheel drive assist
Checking lead on front-wheel assist tractors. The front tires on a front wheel assist tractor need to travel between 2-5% faster than the rear tires. This difference in speed is called LEAD. If the leads is less than this then mechanical and ride problems could be encountered. Symptoms of incorrect lead include:
leaking front differential seals,
excessive front or rear tire wear,
high fuel consumption,
excessive tractor bounce and
the tractor working easier in 2WD mode.
Checking the amount of lead. To check the lead, the mechanical ratio front to rear must be calculated and this compared to the tire ratio front to rear when driving over a smooth flat hard surface.
Mechanical ratio. The mechanical ratio is typically 1.3 to 1.4. This means that the front tires rotate 1.3 to 1.4 times faster than the rear tire. This ratio is sometimes stamped on the transfer box or the front differential. To calculate the mechanical ratio the following steps must be followed:
lift the tractor off the ground so all wheels can turn freely.
put in manual 4WD.
engage Differential lock
run tractor for ten rotations of the rear tire
count number of turns of front tire and part turns. Part turns can be calculated by counting the number of lugs.
Example for MF 362: ****
Back tire 10 turns Front tire *13.75 turns
Therefore mechanical ratio = 13.75/10 = 1.375
*Tire ratio. To calculate the tire ratio, the distance for each revolution of the front and rear tire must be determined. To determine the tire ratio:
make sure the tractors front differential is disengaged.
drive in a straight line on a hard surface for a minimum distance of 50 meters
measure distance covered on firm surface for ten rotations of rear tire
measure distance covered by 14 rotations of front tire
calculate the rolling circumference of the tires
Example for MF 362
Rolling circumference
Back tire - 10 rotations - 38.8 m 3.88 m Front tire - 14 rotations - 42.1 m 3.007 m
Lead = (Front tire rolling circumference) x (Mechanical ratio)/(Back tire rolling circumference)
Example for MF 362
Lead = 3.007 x 1.375 / 3.88=1.07 This tractor has a 7% lead
Desired lead percentage
Sand 5%
Clay 2%
Paddy 7-8%
If lead percentage is too low the back tires are trying to push the front tires and 'windup' will occur in the transmission. This can result in transmission failure, excessive rear tire wear, a rough ride and increased turning circle and poor fuel economy. If the lead is too great, the tractor may have excessive bounce over the front axle, rapid wear of the front tire and excessive soil disturbance under the front tire.
Happy Tractoring
Chipperman
2019 Ford Transit Cutaway Shuttle Bus (A66736)
2019 Ford Transit...
2016 Toyota Camry Sedan (A66738)
2016 Toyota Camry...
TEREX 2300 TEREX 60TON CRANE (INOPERABLE) (A67714)
TEREX 2300 TEREX...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
