Difference between 14" and 16" bottom plow
   / Difference between 14" and 16" bottom plow #1
z4racer
What is the difference between a 14" bottom plow and a 16" bottom plow? I have a 45HP New Holland and would like a single bottom plow for the garden. Does the 16" go deeper? I dont think I could pull a double plow.
   / Difference between 14" and 16" bottom plow #2
I pull a double 14" with a Ford 1710 with 4WD so you should be able to pull a double 16" with what you got.
   / Difference between 14" and 16" bottom plow #3
I believe that the difference is 2".......:) just kidding. I think the measurement is how wide a swath it will plow at a certain depth. You should not have a problem pulling a 2x14" plow with your tractor. I am able to pull a 2 bottom 14" plow with my 35 HP Branson without trouble. I think it's got more to do with weight and ground engagement than it has to do with HP. My Branny weighs a little over 4,000 lbs with the loader and I've got R4 tires.
If farmswithjunk chimes in he can give you alot more info than me.
Mark
   / Difference between 14" and 16" bottom plow #4
you could pull a 2x bottom 16 with no problem.
Mark
I guess my real question is: Does a 14" and 16" plow at the same depth? I want to make sure I can get as deep as possible. I have not been able to find a 16" plow only 12 and 14s.
Thanks for all the responses so far.
   / Difference between 14" and 16" bottom plow #6
Yes, they would plow at the same depth but the 16" would take a 2" wider swath. That means a 16" would be moving more dirt than a 14", thus making it harder to pull. I am sure you could pull a 2X14" plow with your tractor.
Mark
   / Difference between 14" and 16" bottom plow #7
I bought a 2x16 Dearborn plow. I pull it in the sandy soil I have and the tractor does a "fair" job with it. I dont plow too deep with it (I dont want to turn the sand to the top in my soils) and this helps quite a bit.
In my case the HP is not the limiting factor....it's the traction. When I plow, I use 4WD and step on the diff lock to prevent spinning. As I think you have a significantly heavier tractor.....I think you will pull the 2x16 if your soils aren't too heavy.....allthough tires are going to be a factor to consider. Do you have ag tires? industrials? or turf?
Typically plows are designed to plow to a depth of 1/2 of the width. ie the 16" plow is designed to plow at 8" depth. etc. So for a deep plowing job the wider bottoms are preferred.
I would rather have a 2x14 plow for my 790......but the 16 I have works well for my purposes......and it's in great condition. One day I may have a bigger tractor for it. :D;)
   / Difference between 14" and 16" bottom plow #8
The rule of thumb is that a turning plow will plow half it's size in depth. That can be varied by how short you have the top link, so a 14" plow can plow somewhat deeper than 7", but adjusting it that way may affect how completely the soil turns over. Here is a link to a video that shows what I am talking about, and note that he only has a 12" plow.
YouTube - How to - Plow a Garden, Single Bottom Plow, 3pt. Hitch
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
Loader with IH Brackets (A50515)
Loader with IH...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
