diff. lock on john deere 4100
   / diff. lock on john deere 4100 #1
nick_s
new york
john deere 4100 with fel and 54"mmm and jd 400 with fel and brantly backhoe and 60"mmm
Yesterday I went and picked up my used jd 4100hst with 410 bucket and 54 mower from a jd dealerships thats about an hour and a half away. this morning while playing wwith the bucket i noticed the diff. lock wouldnt lock and instead felt like i was inbetween a set of teeth that where ground off. this is while im pushing it all the way down to the floor board. so what im curious is if anyone else has this problem. or if anyone knows if the dealership will fix this for me. the warranty was never explained to me.thanks in advance for any help.
also it does seem that if i keep moving and hold the diff lever and then jam the bucket into the ground once in a great while it will kick it in.
   / diff. lock on john deere 4100 #2
Nick,
You have to stopped to engage it. Otherwise, it just skips over the gaps that the pall is supposed to drop into to engage.
Try this first.
Ralph
   / diff. lock on john deere 4100 #3
Dont force it either - or jump on it.....should use gentle heel pressure
ive tried leting it spin and then stoping and engageing it softly and rather harshly but when i do this it seems to catch for a second or two and starts skipping again
   / diff. lock on john deere 4100 #5
Press down on the lock pedal while stopped as you gently press on the hydro pedal allowing the tractor to slowly start to roll. As it starts to roll, it should drop in.
   / diff. lock on john deere 4100 #6
The differental lock on the JD 4000 series are easy to mess up if over used as I found out. The gears on the teeth get worn down if used a lot. I over used mine and after the second time of wearing out I decided I could make do without.
   / diff. lock on john deere 4100 #7
Yep, I'd say this tractor's diff lock is worn out. Bummer. Since the dealer didn't discuss warranty, I'm guessing you have none.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
1267 (A50490)
1267 (A50490)
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
