Diff-lock doesn't work - BX
/ Diff-lock doesn't work - BX #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
Diff-lock doesn\'t work - BX
I cannot seem to get my diff lock to work. 25 hours on the BX2230 but if I back up on an incline in my yard (at an angle) in 2-wheel drive, one wheel will spin and when I depress the diiff lock, the same wheel still spins as the other does nothing. I don't hear any unusual or suspect noises from the hydro. What could be happening here? /forums/images/graemlins/confused.gif
Thanks all /forums/images/graemlins/smile.gif
/ Diff-lock doesn't work - BX #2
Re: Diff-lock doesn\'t work - BX
I find you need to engage the diff lock slowly while the wheel is slipping by holding down the diff lock pedal. You will feel it drop in as the diff lock pedal will drop further once engaged. I have used mine a handful of times in the snow and mud.
Hope this helps.
/ Diff-lock doesn't work - BX #3
I had that too, I find that turning the front wheels all the way to the left or right does the trick every time.
/ Diff-lock doesn't work - BX #4
I'm assuming that you hold down the Diff Lock petal while using it 'cause it doesn't lock in place. I did that the first couple of times I used it, made me think it wasn't working.
Eric P.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A63569)
HEIN-WERNER 57...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
