Diesel using hydraulic fluid for fuel?
   / Diesel using hydraulic fluid for fuel? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I've heard that a diesel motor can run using hydraulic fluid, I just wondered if anybody actually did it. Well? The thread on vegetable oil got me curious (does it smell like french fries cooking?).
JayC
   / Diesel using hydraulic fluid for fuel? #2
JayC
I believe they would burn a percentage, but why??? Hydraulic oil cost a lot and if its dirty, you would need to filter it well. Yes, like being at McD's if the right blend of cooking oil. I would bet that Hyd. oil would stink in the exhaust.??It's bad enought to whif any of it while doing seat time..
   / Diesel using hydraulic fluid for fuel? #3
Not sure about todays diesels but when I had an '82 chevy pu diesel when I would change fuel filters I would fill the filters up with transmission fluid. The motor didn't know the difference.
   / Diesel using hydraulic fluid for fuel? #4
No way. Especially today's modern diesel engines with particulate filters, urea injection and EGR. Burning anything other than ULSD is a great way to become very familiar with your local repair shop.
   / Diesel using hydraulic fluid for fuel? #5
I was running low on fuel in my JD 755. Instead of going to the store and filling up the cans, I pulled fuel from my deuce and a half. It was about 25% to 35% waste oil, transmission fluid, and hydaulic fluid mix (filtered) to diesel. The tractor ran fine.
I wouldn't put that in my wife's diesel liberty, but older mechanical injected diesels seem to not care as much as long as it isn't too thick to pump. I would not run 100%, but you can cut the diesel with oil. Try a little and see if it makes a difference.
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2 - SIDE MOUNT TOOLBOXES (A53843)
2 - SIDE MOUNT...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
