diesel storage
   / diesel storage #1
sarti
Bronze Member
Central Illinois
Kubota L3901 BX2670
I know this has been gone over a bunch but I'm still not sure of the answer...
I was going to buy one of those 50 gal. plastic tanks from the farm supply store ( the white ones ) to store some diesel fuel in. Will the fuel eat the tank
or cause the plastic to swell? some say yes some no.Some say you can store bio but not reg diesel fuel in them..Thanks for any feed back
   / diesel storage #2
I have stored diesel in plastic tanks for 5 years with no problems.
Chris
   / diesel storage #3
I have been using a 30 gallon plastic drum since back in April or May.
Only paid $12 for it.
Works great.
I've heard the drums are made out of the same stuff the 2 and 5 gallon red and yellow gas and diesel cans are made out of.
I just bought a plastic 55 gallon drum a couple weeks or so ago for $17.
Plan to plump it in with the 30 gallon one on my set up system.
I think I would go with one of those drums over the TSC plastic tanks.
The farm supply store tanks may not even have the correct oppenings/fitting to allow them to be set up as a fuel storage system.
I just saw an add in my local paper where a guy has the 30 gallon drums for 3 bucks apiece.
I want to check them our cause 3 dollars is a steel.
Here are some pictures of my storage and pump set up system.
http://www.tractorbynet.com/forums/1416095-post3.html
http://i283.photobucket.com/albums/kk286/lb59/100_2303.jpg
http://www.tractorbynet.com/forums/oil-fuel-lubricants/41519-poly-drum-legal-fuel-3.html
   / diesel storage #4
You could also ask the farm store people.
As far as swelling, it could happen it you left it out in the blazing sun.
I have a 5 gallon plastic pail with a little hydraulic fluid in it and left it out in the sun. It gets pretty hot up here to over 110F and the pail swelled. So if you did that, it could swell or deform.
Just don't do what I did.:)
   / diesel storage #5
The "answer" is that it is a risk, that you have to be willing to take on yourself.
Go look at the tanks in question, and the manufacturer will be stamped in it.
Call them and ask, and I will be amazed if you find one that say's yes, it is rated for fuel, or it would be fine to store fuel in it.
Will they work, thousands of people are storing fuel in thousands of unapproved, probably improper containers at this very moment. It is working for them.
In the FWIW, my fuel is stored in metal drums.
Also in the FWIW there are companies out there producing fuel compatible plastic containers specter come's to my mind first, if I wanted to store in a plastic drum, I would look at the proper name of the plastic their can was made from, and look for a drum / container with the same plastic.
Good luck
   / diesel storage #6
Al
I don't like/use steel/metal drums because.
1* They rust out
2* Condensation
3* Can't see the fuel level through them <> >< <> That's why I would not take one of the Blue 55 gallon plastic drums for my pump/drum fuel storage set up.
I will say one thing the steel drums make better burning barrels than the plastic drums do.
Larry.
PS:
I just picked up 2 white plastic 30 gallon drums yesterday.
He has 10 more of them that i'm waiting on a phone call so I can make the arrangement to go pick them up also.
   / diesel storage #7
PS:
He has 10 more of them that i'm waiting on a* phone call so I can make the arrangement to go pick them up also.
Up date:
*Got the phone call this evening and went and got the ten 30 gallon drums.
   / diesel storage #8
1*I was going to buy one of those 50 gal. plastic tanks from the farm supply store ( the white ones ) to store some diesel fuel in.
I bought a white 15 gallon tank at Tractor Supply Co ; but took it back when i read the directions that said not for diesel.
What's the price on the 50 gllon tank at your farm supply store?
   / diesel storage
The 50 gal tanks are around $100 at Rural King but I still can't get anyone to commit if you can store diesel in them. The place where I buy my fuel doesn't care if you use plastic or not and says he doesn't THINK it would hurt it. I leaning toward haveing an alum. one fabbed up. the 5gal cans are made of polyethelene and so are the white tanks so I don't really know....Someone has to be able to tell me?????????
   / diesel storage #10
1*The 50 gal tanks are around $100 at Rural King but I still can't get anyone to commit if you can store diesel in them.
2*The place where I buy my fuel doesn't care if you use plastic or not and says he doesn't THINK it would hurt it.
3* I'm leaning toward having an alum one fabbed up.
4* the 5 gal cans are made of polyethylene and so are the white tanks so I don't really know..
1*That's dang high compared to a $17 55 gallon drum.
I have my doubts about the 100 buck tank being any better either.
You could buy about 20 gallon of diesel with the 83 dollar difference.
Hay one of the fuel distributors gave me a real good clean steel 55 gallon drum.
Check out the fuel distributors in your area you might luck out like I did.
2*If it won't hurt then I'd go with a 55 gallon plastic drum.
3*Three things I see wrong with a steel drum / tank.
One rust two condensation three can't see the fuel level in it.
Alum would eliminate one but still leave you with the other two.
So I would not go with this approach.
5*So I'd think either one should / would work.
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
CAT 973 (A47384)
CAT 973 (A47384)
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
