Buying Advice Diesel mower, 60" deck?
   / Diesel mower, 60" deck? #1
MCHam
Wisconsin
John Deere X739, Kubota RTV-X1100C
Hi- looking for advice on lawn tractor/mowers to consider. High-level requirements are diesel, and a 60" deck.
Background
  • Current owner of Deere X720 Ultimate, used for mowing and snowthrowing
  • Have a Kubota RTV-X1100C on order for general land maintenance and snowthrowing (getting the Kubota 66" snowthrower)
  • We mow ~7 acres, some hilly, some rough
  • Because the Kubota is diesel, considering trading in the X720 for a diesel mower
  • Of the Deeres, considering the X750
  • The lawn tractor/mower will only be used for mowing: no snowthrowing, no trailer for hauling, no bucket attachment, etc
Other than the Deere X750 what else should I be looking at?
Of Kubota, I was looking at the BX2380 lawn tractor, but not super comfortable that I am looking at the right specific Kubota model. Also interested in specific other makes/models.
thank you
Thank you Dave! I have never owned a zero turn, am intrigued, but have read that they might not be the best if I have some hills to contend with (?)
   / Diesel mower, 60" deck? #4
Depends on how steep of hills.
Tires also make a huge difference on zero turns.
My hill in the back I had issues mowing much of it and some areas I couldn't mow at all with the stock turfs.
I replaced the crappy stock turfs with bar tires (Carlisle AT 101's)
I can now mow those same hills no problem at all
   / Diesel mower, 60" deck? #5
I run a Kubota diesel zero turn, love it ! Have a few challenging hills but it always do the job.
   / Diesel mower, 60" deck? #6
I have a couple Grasshopper diesel front mount zero turns with 60” decks. They came with bar tires and handle hills great. The suspension seats make a big difference too.
   / Diesel mower, 60" deck? #7
A large ZT with aggressive tires will ride a hill like a boss. A 60”or 72” ZT will mow 7 aces much quicker than a riding mower. I have a 428 Grasshopper with a Kubota diesel and it’s a solid machine that will last a lifetime of homeowner use but personally I’d rather have a Kubota.
   / Diesel mower, 60" deck? #8
I have an Exmark 60” diesel and love it Deere diesel was much more $$. Kubota also makes a good diesel ZTR
I have hills that I only go UP. with the right tires you might go down safely. Are your hills wide enough to go across them?
You should try a ZTR before purchasing.
Wow- I wasn’t expecting this degree of zero turn enthusiasm- I will attempt to find a way to try one out on similar terrain before deciding!
For the most part, yes; however, I do mow a path on a particularly steep hill that I only feel comfortable going down with my current lawn tractor.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
