Diesel Mech advice needed
   / Diesel Mech advice needed #1
Robbie Hegwood
Platinum Member
Georgia
I had an enteresting event Saturday. I have an 04 F-350 powerstroke, cc, lwb, 4x4, srw. I was pulling a hill when something caught my attention. An unusual noise. I lifted a tad only to hear the wastegate bleeding off boost. I looked at my gauge and it was reading 46 psi. exhaust temp 600 degrees and water temp okay and trans temp okay. I tried to lift some but was in heavy traffic and a 18 wheeler close behind. And every time i lifted slightly it was hitting the wastegate alot. After I topped the hill I was able to lift completely and when i got back into the throttle everything was fine. It made for a long hour drive to the job. For info sack i was pulling my tractor, 18k total trailered weight. Any ideas what happened? I have had the EGR tube replaced under warranty and feel it's clogged again but have no idea if they are related. Also had a intercooler tube fail and they replaced that and the plastic piping with metal from the intercooler. Thanks for the help.
   / Diesel Mech advice needed #2
46 psi of boost?
   / Diesel Mech advice needed #4
46 psi is A LOT of boost.
I would definitely try some other diesel forums.
   / Diesel Mech advice needed #5
Never had that problem. I drive a CTD [;)] just kidding ya. Anyhow, I'm not sure about the Powerstrokes but the CTD's have a code system and the codes can be retreived by the owner with 3 turns of the key. If ford has that ability you couls start there and it should tell you what the problem was.
I would say your EGT's were off the charts and the truck may have been defueling on its own to prevent damage. I have an Edge Juice box with the Attitude monitor and my MAX egt's are set at 500. it will then defuel the truck to prevent damage. Not sure what a high EGT temp is with the Powerstroke though. Have you seen 600 EGT's before??? That is quite high.
From what i've gathered fords can go to 1000 degrees for a few minutes at a time without damage. I have read 1100 degrees before danger but that is awful hot. The highest I've been in normal driving while towing is about 750 on a long grade in summer heat. But normal hauling temp 600 degrees max most the time. If it heads higher I'll lift a bit.
The truck didn't seem to be defueling or anything, the only noticable difference was the boost. All other gauges were normal. I think the wastegate or popoff valve(if there different) stuck or hung open or something like that. Because as soon as I lifted completely it was fine.
I was sure I had run into the weak head gasket theory and blown one. What really concerned me was getting my tractor/trailer home and how much it would cost to do so.
   / Diesel Mech advice needed #7
i don't know where you guy's are measuring your egt's at but 600* before the turbo is nothing. you can safely run 1250* all day long. **** i've had my 1600* gauge pegged more times than i can count for 10-20 seconds at a time.
   / Diesel Mech advice needed #8
I want to make sure I understand correctly. I am not a diesel mechanic (at all) but I think I have had the same thing happen. Before I went with the Banks System, I was running a boost gauge, 80 hp Superchip, and exhaust with temp gauge. Once, when pulling my tractor up Black Mountain, near Asheville, NC in overdrive, I noticed my EGT going up. I have understood that over 1200 degrees is bad for PSD's, and going up this hill, mine reached about 900 degrees. My boost read 22 psi and the waste gate clicking started and the truck seemed to level a bit in power, if not lose some. My impression of this event was that it was an EGT/defueling event and it resolved soon after cresting the hill. Since I have changed to a full Banks System and away from the chip exhaust combo, I have pulled the same hill with less temp and no problems. My max boost even running what is a max'd out system is 28 psi, so I suspect the 46 was an error. If these events seem similar, I would say I have run the same run many times since without incident and with no engine maladies. I have friends who have said when EGT's change drastically this event has happened to them also. I have not heard anyone mention gauges reading erratically. I am assuming you are running aftermarket gauges, as I do not recall my PSD having a boost gauge stock. Also, I do not know if you are running any power adders, such as a chip, which could have started such a process by increasing the fuel load.
John M
   / Diesel Mech advice needed #9
First of all pulling an 18k load is nothing to sneeze at.
46psi of boost is rather high but with only 600deg on your egt temp. That kind of boost means it is pouring the coals to it and as we well know fuel = heat = high egts....something is just not adding up.
Let's simplify this. Is there a device ( wastegate, popoff valve, etc.) that could cause the boost to increase 10 psi momentarly but that could reset itself??? My truck does have a banks exhaust which I feel is invaluable. I think I would melt everything without it. I also have a K & N air filter so as to let the motor breath as much as possible. I'm fairly sure the boost gauge was acurate because of the wastegate blowing off boost the instant i lifted. Usaully the wastgate only blows when you close the throttle quickly. I was easing out of the throttle so it shouldn't have hit the wastegate. Does that make since? The highest boost normally is about 36-38 psi max.
Yes I am trying to kill my truck. Death by weight!!! Now you know why i want a medium duty truck. Having to make due in the meantime.
Thanks for the replies. Robbie
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
378705 (A51573)
378705 (A51573)
378577 (A51573)
378577 (A51573)
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
