Oil & Fuel Diesel leak from injector pump?
   / Diesel leak from injector pump? #1
Kenfyoozed
Mobile, Al
1974 MF135
I am still learning about my mf135 and all things related. She has had a fuel leaks for a while, but nothing major. So I decided i needed to start cleaning her up and repairing what I could. I found the leak to be a loose connection from the primary pump. But as fate would have it she sprang another leak. It seems be coming from the injector pump? That would be the piece of hardware on the left side with all the hard lines coming from it, correct? It has a small block off style plate that is secured with 2 small bolts. It seems to be coming from that block off plate. I assumne there is some type of gasket under the plate? And removing this plate allows air in and requires bleeding of the lines, correct?
So how far off base am I? Also where , online could I purchase fuel related parts? And how much is a new injector pump? Or do I even want to know?
Neil
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2023 BOBCAT T76R SERIES SKID STEER (A51242)
2023 BOBCAT T76R...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
(INOP) 2014 CATERPILLAR 279D SKID STEER (A51242)
(INOP) 2014...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
