Diesel goes into the oil chamber,
   / Diesel goes into the oil chamber, #1
rfgonzaba56
Texas
kubota
I have an old diesel tractor Massey Ferguson 135. Everything works fine except that diesel keeps going into the oil chamber. What can be done to correct the situation? I had a gas lawn tractor and the gas kept going into the oil chamber, the next day the gas tank was empty. I corrected the problem by replacing the carburator because it worked with gravity.
   / Diesel goes into the oil chamber, #2
Gas engine benefits from an add-on/in-line shut-off, even with a 'good' carb.
Diesel may have a leaking seal in the injector pump. If so, I'd expect fuel to leak into the engine when running vs when parked.
   / Diesel goes into the oil chamber, #3
Yep, most likely a seal in the fuel pump, or lift pump if it has one. This would leak fuel into the engine crankcase, especially if the fuel tank is above the engine, and even if the engine isn't running. Dutchy
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2014 Chevrolet Silverado Pickup Truck, VIN # 1GC1KXEG9EF156183 (A51572)
2014 Chevrolet...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
