Oil & Fuel Diesel Gal/Hr
/ Diesel Gal/Hr #81
JimBinMI - I understand your feelings about your dog. How are the kids about it? 14 and 12 are pretty rough ages to deal with things like that. Not that it's a lot easier as you get older, for that matter, I guess.
We've got a Himalayan cat ("Butterscotch") to keep the Pomeranian dog ("Cinnamon") in line. (You can tell what we think about around here.) It's enjoyable to watch them horse around. They're a lot of company.
Mark
/ Diesel Gal/Hr #82
MarkC,
The first time I took him to the Vet and warned the kids ahead of time, since he was paralyzed from the waist down, that I didn't know if I'd be bringing him home or not and they got pretty emotional. $400 and several days later he was better and walking then about a month later he became paralyzed again, the doctor had told us that they could do surgery for several thousand dollars and that's when I took him and had him put down. The kids are OK now but we still miss Dudley and reflect fondly on his time with us.
Our cat used to keep Dudley in line when he needed it too!
JimBinMI
We boys and our toys!
/ Diesel Gal/Hr #83
When I posted my fuel consumption before, I was guesstimating how much was still in the barrel, but I had to buy another barrel of diesel yesterday, so I was able to get more accurate numbers and found that my fuel consumption has been .705 gal/hr for the first 191.7 hours.
Bird
/ Diesel Gal/Hr #84
First 100 hrs on my TC33 has worked out to 0.7 gal/hr. I made an attempt to refine this as a function of the type of work but I'm afraid I lost control when my dear wife took over brush hogging! I have noticed very significant variability in this and for my work, the toughest duty is clearly brush hogging. This consumes 1.0 gal/hr. I do have a hydro, some hills, and run the front higher (maybe I have thick grass too - it's still green in MI!). This contrasts with light duty work where I end up around 0.5 gal/hr - I used between 2 and 3 gal in 5 hr today with light loader, scraper, and auger work (18 postholes and lots of carrying things hither and yon). Some good news is the price of gasoline in my area has dropped 60 cents in the past 3 weeks - price of diesel has dropped 2 cents!
/ Diesel Gal/Hr #85
Mark, Wen and others,
Here is a very small sampling for my New Holland TC18 HST 4x4 (18.5 hp)
At 80 hours on the meter, I filled it up. Today, at 85.5 hours it took roughly 3 gallons to fill it up. So, 3/5.5=.545 gallons/hour. The 5.5 hours were mowing at 2450 rpm and moving fill sand at about 1800 rpm.
I purchased 11 gallons in two containers today and will keep record for those 11 gallons and report back. I'm impressed with this economy and am sure it uses less fuel that my old gas 16 hp Kohler that was in my garden tractor.
JimBinMI
/ Diesel Gal/Hr #86
JimBinMI - Sounds like you're burning a miserly amount there. I expect you're right - I'd bet you're burning about half what the 16hp gas Kohler was, in fact.
Mark
/ Diesel Gal/Hr #87
Yeah, Mike, whether it's working hard or not does make a difference. Mine used more than the average the last couple of days, too, brush hogging really thick and tall grass and weeds. Of course, most of it wasn't taller than the wheels, but I actually had a little Johnson grass as tall as the canopy. I'm not real fond of driving into stuff like that where you can't see a thing and don't know what you might run over, but fortunately there was nothing unusual in it.
Bird
/ Diesel Gal/Hr #88
I've got four more GPH averages to report: a 7.5 hour sample at .77 GPH, a 15.2 hour sample at .69 GPH, an 11.3 hour sample at .69 GPH, and a 28.1 hour sample at .73. My overall average consumption, for the life of the tractor, is .69 GPH. Pretty much all of these samples were from very hard usage at high rpms, doing work I've described elsewhere: Pulling up trees, digging with the loader or tiller in very hard soil, moving boulders, bush-hogging, etc.
MarkC
/ Diesel Gal/Hr #89
Guys,
Here's another sampling from the Mighty NH TC18 Hydro 4WD.
Went 24 Hours on 11 Gallons = .4583 Gallons/Hour!
Sounds GOOD to me! /w3tcompact/icons/smile.gif
JimBinMI
/ Diesel Gal/Hr #91
I just saw this post pop back up on fuel consumption and it reminded me that I've been keeping track of diesel fuel purchases and consumption since mid-May. For my little B7100 HST I've run:
- since May 13 - 126 hrs.
- 100 gal. fuel -
- average usage - .769 gal. per hr.
Now, this is probably about 85% yard mowing with the 60" mid-mounted deck, 10-12% bush hogging, and the rest working with the back blade grading a couple of driveways. I usually mow & bush hog at about full throttle and do have some hills to contend with.
I don't really know if this is good fuel economy for a B7100 HST, but I'm satisfied with it. I also have an older JD 316 lawn/garden tractor that I still use for lawn mowing around the house and buildings and it doesn't burn gas near that efficiency level per hour (uses lots more).
Bob Pence
/ Diesel Gal/Hr #92
JimBinMI,
My mighty NH TC40D just consumed 10 gallons in 8 hours = 1.25 gallons/Hour! Maybe I could use that coffee cup for the tractor that we've seen in some other posts./w3tcompact/icons/smile.gif Of course I was running at full RPM digging a driveway (very heavy load). I'm not complaining though, if I had to do that work by hand ... /w3tcompact/icons/crazy.gif I'm not even gonna think about it.
When not under that load and at a lower rpm the consumption rate is around .8 gallons/hour.
/ Diesel Gal/Hr #93
Any updates on the fuel economy question? Gordon now has over 10,000 hours. Is the fuel usage still about the same?
Also, for Rogue and TresCrows. How are your BX's stacking up against the 7100 and 7500 series? You guys figured out how much diesel you're burning yet?
SHF
/ Diesel Gal/Hr #94
I never noticed this thread before. I haven't been keeping real strict usage logs, but I know I haven't used 15 gallons of diesel yet, and I have 38 hours on my B7500. I'm not sure if my hour meter is factored by the tachometer, but since they are co-located, I suspect that it is. I have about 4 gallons left in the tank, so I "guess" I've actually used 11 gallons over a 38 hour period. Is this possible?!? /w3tcompact/icons/shocked.gif
I can't believe that I'm using less than 1/2 a gallon per hour!
The GlueGuy
/ Diesel Gal/Hr #95
Glue Guy,
It appears that your usage is in line with the past posts. This is really economical. I don't think my little 4 cylinder car could IDLE for an hour and use less than a gallon of fuel. There seems to be some correlation between size of the engine and diesel usage, but not as much as I would expect.
SHF
/ Diesel Gal/Hr #96
Hey Glueguy, Yes, its about right. I've had my B7300 since sept 00 and it came with full tank. I have put 18 gallons through it and only put on 40 hours.
My 14 HP briggs & stratten on my troy bilt tractor uses twice that. My Case DC (33HP) when used for log splitting was going through upwards of 3 gallons (gas) per hour. I quickly adapted my splitter to run off the Bota. What a difference.
Diesel Rules!
Steve
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
1996 International Water Truck with a Caterpillar Engine (A61307)
1996 International...
