Diesel fuel treatment
   / Diesel fuel treatment #1
Rohdog
Clyde, Ohio
1978 D6806 Deutz,1966 MF 135
Anyone ever try seafoam in diesel fuel tractor? Do you put it in fuel filter or just add to tank?
   / Diesel fuel treatment #3
Skip the seafoam and go straight to Howes.
Thank you, I' getting tired of this snow and cold..here in northern ohio...i'm sure it's the same in Wisconsin. Giving my tractor a workout this winter..for sure.
What is Howes?...better than seafoam?...add to fuel or add to fuel filter when new? I have power service in fuel now but I want something to clean fuel system.
   / Diesel fuel treatment #6
Seafoam, also known as snake oil. Is only IPA, naphtha gasoline and baby oil/mineral oil.
Save your money and run #1 dewaxed diesel in the winter. Dose it with a little IPA to absorb the water.
I do run off road diesel...with power service.....maybe i'll just leave it be.
   / Diesel fuel treatment #8
seafoam is not worth the money for regular use! I used to use it but it cost 4 times as much as Lucas fuel additive. For gasoline I only add ISO heat alcohol fall and spring. I change my filters and the fuel additives are not worth the money.
For diesel only add a winter anti gel. Can't trust the pump around here. Howes an power service are great anti gel around here!
   / Diesel fuel treatment #10
I used to use Power Service white bottle, until they changed the formula and instructions. They now warn to only use it in cold months. I switched to Howes Diesel Treat, which can be found just as easily, and it can be used year round. No gel problems.
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
2025 Icon Electric Utility Cart with Dump bed (A51694)
2025 Icon Electric...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2014 Nissan Rogue Select S AWD SUV (A51694)
2014 Nissan Rogue...
