Diesel Fuel System question?
   / Diesel Fuel System question? #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
Hesston 1180, Fiat 865 engine.
Bogged down while mowing and died.
Changed the 2 fuel filters.
While trying to bleed as per manual, could not get any fuel with the hand pump.
We only had fuel in lower tank (below filter level) so figured we would pressurize the tanks at the filler neck and force it through.
Was able to get good pressure on tanks, but no fuel flow at filters.
My question is, does the pump block the flow, maybe unless the handle is in a certain position?
Or maybe my tank outlet is blocked.
What we might be overlooking?
Thank you for any suggestions.
   / Diesel Fuel System question? #2
Don't know about your specific model but it sounds like the line is restricted. I would pull the line loose where ever it first gets to the engine compartment and blow back to see if it is free to the tank. Then I would look forward for debris that may be restricting the flow.
I fought a restriction on my backhoe when I first got it and finally found a little chunk of rust in the banjo fitting at the water separator.
   / Diesel Fuel System question? #3
Being the Hesston a rebadged Fiat, I would check the fuel tank screen. The Italian liked to use a screen on the fuel tank, often with a shutoff ball attached to it.
I have had the same problem on another Italian crawler tractor, a 1960-ish gem, after checking all filters and lines, finally took the shut off valve and screen off the tank and it was full of crap and rust.
Well it was all my fault. My filters came with 3 rubber gaskets and 2 o-rings. Only 2 rubber gaskets were needed. I thought they were all the same, but were not. We installed the smaller gasket on the top of the filter (it should have been thrown away). It was blocking fuel flow. The larger gasket sealed the filter to mounting correctly and let the fuel in. All is well now.
   / Diesel Fuel System question? #5
Easy fix! We always like easy fixes.
Thanks for letting us know the outcome. :thumbsup:
   / Diesel Fuel System question? #6
Yep, the CAV-style filters are made to fit many different machines and arrangements. The small O-rings are often used under the head of the filter mounting through-bolt. (Between the filter head and bolt/washer.)
I just installed a new 2-filter head on my "on-going" Ford project. A new fabricated bracket and one supply line mod is all it took. The new filter setup has a glass bowl and drain for water inspection/removal.
2013 FORD F150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F150 XL...
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
14ft. Deer Gate (A53424)
14ft. Deer Gate...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
