Diesel Fuel In Crank Case
   / Diesel Fuel In Crank Case #1
swampper
Hayward, Wi
Massy 180
I have a Massey 180 with Perkins 4 in it. I have replaced the lift pump. When removed i could see nothing wrong in the old one. After three hrs of running, the crankcase is full of diesel. One strange thing thing about its behavior is after it is used for an hour, It,s first compression stroke when restarting, sounds like there is a hydraulic lock and will not turn over properly. Injector or Injector pump? The diesel shop that i talked to said that the IP i have is the type that you must dismantle the pump to remove the shaft to replace the seal.
I'm trying not to make a costly mistake. The IP seal work about 450.00
Thanks for your help. Lyle
   / Diesel Fuel In Crank Case #2
I can reseal the pump for you, just mailed a 165 pump back for the same trouble. E-mail mhf35diesel@yahoo.com or call 574 893 4172, after 7 PM is best. Won't be home until late wensday eve, but will be thursday. Be glad to help.
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
2018 COLOMBO TM LOT IDENTIFIER 247 (A53084)
2018 COLOMBO TM...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
