ehinson
Bronze Member
I know this is a topic of much debate but I am curious if anyone with the regen woes has tried any Diesel Fuel additives experienced any positive or negative results?
If you do, or will start using it would be great to share your results with everyone.
I don't have a model that regens but I'm sure one day I may.
I myself have been using PRI-D and PRI-G for my gasoline engines, but I will likely change since there isn't allot of data on it and from what I have been reading about Stanadyne & Diesel Kleen I will give one of them a long run.
I have found several companies that have products that specifically reference tier 4 engines.
Here are a few links.
4 Best Diesel Fuel Additives of 217 (And Why They Work)
For first time, Cummins recommends fuel additives for its diesel engines | Equipment World | Construction Equipment, News and Information | Heavy Construction Equipment
DIESEL ENGINE SCR AND DPF REGEN SYSTEMS WHEN USED WITH DIESEL FUEL ADDITIVES
