diesel for generator
/ diesel for generator #161
I think it was already covered that about 95% of the fuel in NA was ULSD, .. thus.. while it is not 100% gone..
* for the most part.. those of us that don't own a train don't see it ;)
soundguy
*Maybe we should should rush out and buy a train before it's no longe available for them .
/ diesel for generator #163
my 7.3 Powerstroke sounds like a freight trane.. does that count? :)
soundguy
/ diesel for generator #164
soundguy
Ya my powerstroke sure sounds better and throatier than my cocge cummins. but i still want the train horn.
/ diesel for generator #165
i do need to get an air horn for my 450.. would be fitting. could put it under the aluminum scoop..
/ diesel for generator #167
Howdy,
Not to bring up a older thread, but
The manufacturer is just covering thier bases with a blanket statement about diesel fuel type. I only have access to ULSD here. As you say by the posting earlier, he was able to by LSD (500ppm). There still might be stockpiles of LSD out there which are being sold. Yes, you can contact your supplier and make sure you only receive ULSD. You are a smarter consumer than some out there. Ford would want to deny your 2011 Ford diesel truck too if you ran a bunch of 500ppm stuff and clogged up stuff.
Warranty coverage should not be an issue if you feed it the right type of fuel. That means wether its on road, or off-road (dyed) and is ULSD, then you will not have the catalytic converter issue with any newer TIER 3 or 4 engine. You might have some other warranty claim, but not one involving a clogged converter
"quote from aurora generator fuel oil myths"
"Off-road fuel and red dyed fuel are designed to run on different engines. The sulfur content in red fuel is 500-1000 ppm Your engine and catalytic converter are designed for fuels with less then 10ppm. If you use those fuels, you will deactivate the catalyst and lead to soot clogging of the converter core. We see it all the time. Converters deactivated, over heated engines and exhaust systems glowing red hot from all the soot inside them. Often they catch on fire."
Some here are getting a little testy about a manufacturer warranty. A diesel engine which is broken in (new genset and you run it 20 hours) is most likely to not have an issue. Same thing with a tractor. A new tractor passes by 10, 20, 30 40 50--- hours, and your onward. The regulations are changing. It would be nice to say all off-road diesel is 15ppm world wide. It's not. I really think that if you fed your new generator a bunch of LSD 500ppm and had catalytic converter problems, you are on your own.
off stage, exit left~~~~
/ diesel for generator #168
New thought...
It's a Yanmar ripoff copy right?
Has anyone looked up Yanmar's warranty on this design to see if they have the same suspicious no warranty clause?
/ diesel for generator #169
The Aurora says it has a catalic (sp?) converter in the exhaust that will get fouled with off-road. maybe, maybe not.....I was wondering if I could REMOVE that piece of wonderment and it would NEVER get fouled :)
Thoughts?
I think the issue is the sulfur content of the fuel, not whether it's off-road or on-road. People always mix this up and equate the two where they shouldn't.
Off-road just means there is no highway tax in the fuel price, and the fuel is dyed red to indicate that. This is not a reliable indicator of sulfur content.
On-road diesel MUST be 15 PPM or less sulfur, otherwise known as ULSD (Ultra low Sulfur Diesel), so buying on-road assures you are buying ULSD. That relationship is reliable, i.e. on-road = Highway taxes = no red dye = ULSD
Off-road is not REQUIRED to be ULSD, but in practice it almost always is. Just ask the fuel distributor/dealer to confirm. So off-road = no highway taxes = red dye = (ULSD or LSD). In other words, it might be ULSD, but it's not guaranteed - you need to ask/check.
I just had my 250 gal storage tank filled the other day and it says right on the slip that it's off-road ULSD. Good thing because my excavator requires ULSD.
/ diesel for generator #170
I just wish manufacturers would state their fuel requirements directly rather than obliquely. If their engine requires ULSD, then f%#&(ing say that, not something else. My excavator has a sticker next to the fuel tank that says only to use ULSD. It's perfectly clear what they want, and there's no confusion or speculation over whether red dye will ruin the machine, or not paying taxes is un-American, or whatever. It needs low sulfur fuel, so say THAT, not something else.
/ diesel for generator #171
Howdy,
Exactly. My gators even have a sticker by the fuel tank saying use "Low Sulpher Diesel or Ultra Low Sulpher Diesel Only". OK it has the yanmar diesel engine in it. My last fill up with LSD 500ppm stuff was maybe 4 years ago now. (Northern Virginia) It has always been ULSD from then onward. (Off-Road #2 Diesel ULSD) dyed red, but same as your station pumped ULSD diesel.
/ diesel for generator #172
Been a few more months now......
Are there any AURORA guys out there with MORE INPUT about their generators?
I plan on buying one in March......Still the best diesel option? (for the money)
can't afford a Kubota or Yanmar.....
Thanks for any updates.:ashamed:
Rob
I have used mine a few times since I got it and it has been running fine. The only problem I had was with the solenoid for the shut off switch not working. I had to manually shut it down. After a few emails and phone calls, Aurora sent me a new solenoid/cable assembly and all is fine.
I am running the ULSD from the gas station for warranty reasons, but I talked to my fuel oil distributor last month. He also has pumps that are key operated for people with accounts and he sells on-road, off-road, kero and gas. He said the on-road and off-road are the exact same thing, the dye in the non-taxed is the only difference.
/ diesel for generator #174
So is Home heating oil and fuel oil.
/ diesel for generator #177
to get off road I either have to buy it from work, or hit 1 of the 2 stations the next town up to get it. both are a bit of a PITA
378892 (A61166)
378892 (A61166)
2014 F-150 STX (A56438)
2014 F-150 STX...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
832710 (A61166)
832710 (A61166)
DOOSAN 5K FORKLIFT  G25P-5 (A60736)
DOOSAN 5K FORKLIFT...
1762 (A58375)
1762 (A58375)
