Diesel and Grease?
   / Diesel and Grease? #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
I have a question about the grading of Diesel. What is the difference between grade 1 and grade 2 ? Is there an additive in the grade 1? I admit to being new to owning a diesel tractor, and although I drive truck for a living, I know nothing about fuel. My company buys it, and I fuel when I return. The second question is about grease. What is the proper amount of grease to apply to the loader fitting? It seems like some of these connections could use grease. They have a dry look. Does the same rule apply to this as does cars, and such? You grease until grease comes out the side? I don't want to have grease all over the place. Thanks as always!!! Kent
   / Diesel and Grease? #2
#1 is less viscous and has less paraffin than #2 (and therefore less power). It is not because it has an additive; it's refined differently. #2 is the fuel of preference but because has problems in cold weather, #1 is the fuel of choice when it's cold. #1 can be hard to find, but you can substitue kerosene or Jet-A if you can obtain those. It is usually preferable to blend #1 (or kero or Jet-A) in about a 50/50 mix with #2 as that gives you a good compromise and will usually not gel up unless it gets really, really cold (like -20F or so).
You can put too much grease in a fitting if it has seals. If it's open, overgreasing just makes a mess.
Thanks for the info cp1969, I'm grateful for the reply. Kent
JCB 505-TC 4x4 Rough Terrain Telehandler (A49461)
JCB 505-TC 4x4...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
John Deere No. 3 Sickle Mower (A50860)
John Deere No. 3...
197637 (A50459)
197637 (A50459)
2022 Club Car...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
