Oil & Fuel Did something stupid.....
   / Did something stupid..... #1
JDKu
Bronze Member
Calgary, Alberta, Canada
GC2300
....changed the transmission fluid. Drained the catch pan into an empty oil engine oil jug. Then proceeded to change my engine oil accidentaly using the drained transmission fluid.
Idled the tractor for a few minutes max, backed it out of the garage and noticed the real jug of diesel oil on the bench. Wandered around for 60 seconds trying to figure out what I had just done. Then I clued in. I shut the tractor off. Drained the oil. Pulled the filter and "flushed clean" with some diesel fuel. Poured some car oil through it to try and flush some of the transmission fluid out. Partially filled with car oil (1 or 2 liters) and then drained. Filled with diesel oil. Ran for 5 minutes. Currently draining. I plan to install new filter and new diesel oil when I get to town and can get some. Anything else I should do?
Can't believe I did this - I always tear off the label on jugs of used oil to prevent things like this from happening. The used transmission fluid looked as clear as new oil.....glad I caught it.....
   / Did something stupid..... #2
If I did that(....and i I've done stuff like that...as much as I hate to admit it). I would worry more about the fact that I was capable of that sort of thing then what effect it had on the machine.
You just cleaned your engine weather it needed it or not.
I would think there is no harm done...wouldn't wait to long before my next oil change, but your alright( except for that brain fade).
Have a lot on your mind lately?
I always have a lot on my mind.....just the wrong things at times!
   / Did something stupid..... #4
G'day put some new oil and filter and away you go don't think you would have done damage it was not like you were under heavy load or anything
Jon
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
196046 (A50459)
196046 (A50459)
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
JLG 1255 Telehandler (A51039)
JLG 1255...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
