DmansPadge
Veteran Member
- Joined
- Oct 3, 2004
- Messages
- 1,698
- Location
- Orange, TX
- Tractor
- Kubota B2620, Toro 2000 Series Z Master
Oops...
I've got an old Bush Hog cutter that was given to me and it stays out in the elements. It has two chains hanging from the top of the 3pt hitch and I use them to keep the shaft up in the air so it isn't just laying in the dirt. I tie the two pieces of chain together with one of those screw together chain links. This chain is decent size.... 5/16 or 3/8 maybe. (see attached pic) The other day I hooked up to the cutter and managed to hook up everything while forgetting to undo the support from the shaft. When I lifted the cutter it changed angles and put pressure on the chain holding the PTO shaft and it forced the chain link to fail.... bending it up pretty good. I got off the tractor, secured the chains and began cutting. But once I started I had it in my head maybe the shaft bent some and the more I thought about it the more I could feel a vibration. This may totally be in my head just because I knew what just happened. I pushed back the shield on the shaft to look at the actual shaft spinning and it appeared to not be perfectly straight as it wobbled some as it turned. Now I'm wondering if that shaft might have a slight bend in it and that it will put undue stress on the tractor's PTO. The chain link did fail so maybe that is all that bent but I don't want to damage the tractor either. Maybe I should just get another center section of the PTO shaft to be safe? Thoughts?
Thanks.
Thanks.
