Diamond C Trailers
   / Diamond C Trailers #1
two_bit_score
Super Star Member
Texas - from the brush and pear to the piney woods
John Deere 110 TLB, Diamond C 19LPX GN trailer
Looking at this trailer to haul the JD 110 TLB. Looking at 20' length. What are your thoughts?
GVWR: 14,000#
Axles: 2-7000# E-Z Lube Axles - 2 Elect. Brakes
Coupler: 2-5/16 30,000# Load Leveler
Cross Members: 3 Channel on 16 centers
Frame: 7 Channel
Fender: 9 X 72 Teardrop 14Ga Diamond Plate
Jack: 12,000# Dropleg
Neck: 8 Channel
Ramps: 5 3 Channel (Slide-in Rear)
Spare Mount: In Neck
Suspension: 6-Leaf Slipper
Tie Downs: 6 Stake Pockets & 4 Equipment 泥 Rings
Tires: ST235/80R16
Wheels: 16 8 Hole
Extreme Duty Fleetneck Trailer | 18EEQ-FN - 16' x 82" | Diamond C
Available Options
Axles: 4 Drop Axles (approx 3 of bed width lost)
Equalizer Torsion Axles (approx 3 of bed width lost)(2 Brakes)
Dove : 2 Diamond Plate
Floor: 3/16 Diamond Plate
Jack: 2nd 12,000# Drop-leg Jack
7K Stabilizer Drop-Leg
Paint: Paint Underneath
Special Color
Ramps : 5 Flip-Knee (4 Channel)
Rub Rail: Rub Rail and Stake Pockets (Calculated on Total Trailer Length)
Skid-Steer Pkg: Drop Axles, Dovetail, & 42 Stand-up Ramps
Spares: Spare Tire & Wheel (ST235/80R16)
Stake Pockets: Extra
Tie Downs: HD Equipment 泥 Rings
Code:
[CODE]
[/CODE]
   / Diamond C Trailers #2
Is that enough trailer for a JD 110 TLB. I though they were about 9,000# or so. A 14K trailer like that has to weigh in at 4,500 to 5,000# empty and that will not leave a lot of wiggle room on weight.
I would go bigger in the GVWR and also lenght. I do like the low boy style of that trailer though.
Chris
Chris, after deducting the trailer weight the payload is 11,200 lbs. The 110 is about 7,600 per JD so wouldn't I be safe with allowing about 1k more for fuel, etc?
   / Diamond C Trailers #4
That is lighter than what I though. Are you sure that is with the BH? I have seen that weight or there about's 7,500# with the tractor/loader but did not include the weight of the BH???? We looked at some 110 without the BH a few years back for my neighbor but could never make them work money wise by the time you added the BH.
I very well may be wrong here, I have never owned one. My neighbor looked at them very hard a few years back and soon realized it was too much for his Dmax so he ended up with a older Case Construction King for $5000 that was about 13,500# and bought a couple dump trucks and a heavier trailer with all the money he saved.
Like I said, I very well may be wrong but I thought the 110 TLB was right around 9,000#
Chris
You may have a point. I've always considered the TLB to be about 7,600# but that's based on what I've been told. The JD website shoes the tractor, loader and box blade to be ~ 7,300 but no weight s given for the "TLB" with the backhoe. Could the difference in the hoe and box blade be more than 700#?
Operating Weight w/Backhoe, lb. (kg) ---
Operating Weight w/Loader and Box Blade, lb. (kg) 7280 (3302)
   / Diamond C Trailers #6
I have a '99 Diamond C Fleetneck trailer. 28', dual tandem dovetail with 12,000# axles. Never had any problems with it. That's a nice trailer you're looking at but I think you might want to call Diamond C and tell them what you want to haul and ask their recommendations about it.
Good point. Thanks for the info about Diamond C. Does your trailer have the slipper springs?
   / Diamond C Trailers #8
Easily. My little 6' BH I had for my Jinma 284 weighed 1,050#. I would guess the 110's BH would weigh 1,500# or more.
Chris
   / Diamond C Trailers #9
i cant speak for that trailer since i have used one but we run a fleetneck and diamond c dual tadems and every tractor dealer with 100 miles of my shop has one i believe Diamond C and Fleet neck are some of the best traliers built i have also run some of the low gooseneck utilty trailer and have had them loaded heavy hauling a 6610s and a 3600 ford tractors at the same time and went 300 miles with no trouble they really are some good trailers and really well built
and i believe the trailer you are looking at is plenty big enough for your backhoe i haul a 555 ford and a 4500 on a 18ft gooseneck with two 7000lb axles not both machines at one time
The Jd 110 tlb weight around 7k
3in Poly Pipe (A49461)
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
