lawncareguy
Hi all-
I've been trying to figure out the problem with a Kohler CH23S 23 hp engine on an Exmark mower. It starts and runs, but stalls when trying to cut grass- seems to have no power. I checked the spark plugs and they seem fine- visual inspection is good, and I can see them spark if I hook them up to a weed whacker (can't crank engine now because I have taken it apart, but plug on the suspected bad side was wet when I took it out). When I first started working on the mower, I tested it by pulling the spark plug wires one at a time to see which cylinder the engine was running on- I found that it would run on the right spark plug wire alone, but not the left one alone. Since the spark plugs were fine, I concluded that the problem was the ignition coil, and I disassembled the front of the engine and took it out. HOWEVER, I measured the resistance of the old coil between the spark plug boot and the screw holes in the coil and found the resistance to be 9.4 k-ohm, which is very similar to the resistance of a new coil I bought, and seems to be in the acceptable range. The ignition coil has one wire going to it, which is the one that grounds it out to shut off the engine. I tested this with the key on off and run, and both positions seem to be working properly. I can't quite remember what the air gap measured before I took the coil out, but I did check it and must have thought at the time that the air gap was reasonable, so it must have been somewhere between 11 and 16 thousandths, likely on the low-medium side of this range.
So my question is this: Could the ignition coil be the problem, and if not, what else should I check?
I have been using this manual, and the electrical systems part starts on pg 41
