dfw file to pdf?
   / dfw file to pdf? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
anyone know of any free software to convert dfw files ( autodesk? ) to pdf format?
thanks
soundguy
   / dfw file to pdf? #2
I don't have autodesk or dfw files, but can use Cute .PDF will all my applications: CutePDF - Create PDF for free, Free PDF Utilities, Edit PDF easily;.
It installs into the system and appears under the printer menu - simply open the document you want to convert and send ot to print using cutepdf as the printer. You then get a pop-up asking you what file name / folder to save it as.
The link above goes to the cute pdf website, where it is free to download. Depending upon your system you may also need a ghost scrip editor - also available on the website.
Hope this helps.
   / dfw file to pdf?
thanks, will take a look!
soundguy
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
White Metal Roof Panels (A55758)
White Metal Roof...
Auger Drill Bit (A56857)
Auger Drill Bit...
Peterbilt 377 Semi-Truck (A56435)
Peterbilt 377...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
