Hello!
I have a Agrokid 45 of 2001 (with 714 hours) with various problems. I want to share these issues with you to find solutions if possible. I will try to explain them as best as possible.
1 - Gearbox: very hard; the inverter and the box. But if the speeds were hard and entering always gave me satisfied, but especially at high speeds they enter not always. Example: I will in third speed and if want to reduce to second speed, i have to brake the tractor if not the speed does not enter. Is there anything you can do to put the gear box more soft and the speeds always enter? Other thing: the lever groups/creeper (HML) sometimes gets stuck / blocks and can not engage the group; to example, sometimes is in M, can go to the L, but does not enter H (the sequence is HLM); sometimes not move, and sometimes enter perfectly. What do when you can not engage a group is as follows: I do double clutch / put the box and the inverter in N (sometimes works); I move the tractor slightly (almost always works); I know you may not believe, but if you do not press the clutch, I can move it easily and does not scratch anything (at least not hear any noise). Is normal?
2- Brakes: are discs in oil bath. Are very hard and brake bad. With the tractor with an implement in the hydraulic or the tractor alone, the brakes do their job; the problem is with the loaded trailer; I have literally put me on the pedals to the tractor slow down, do not even say brake. Someone advice?
3- Heating: problem solved with a fan with seven blades and changing the radiator nest.
And a few more problems for now I will not talk. If you can help me, I would be grateful. I would also like to hear opinions of the owners of these models.
