Oil & Fuel Deutz Fahr Agro Plus 67 (2013) hydraulics
   / Deutz Fahr Agro Plus 67 (2013) hydraulics #1
Erle
Sedalia, Missouri
Deutz Fahr Agro Plus 67, Massey Ferguson 40B, Massey Ferguson 50A, Massey Ferguson Super 90
Tractor has 1130 hours. Hydraulics work great for about an hour. After they get hot they will not lift(3 point or hydraulic ports) Have purchased all new filters, although I would expect this to be more of a pump issue than a filter problem. Need to know what kind of hydraulic fluid to replace with as I can't find Akros Multi fluid. Also pump location, testing / verification and possibly where to find a service manual for the tractor. Finding info for this tractor online is almost impossible. Only other problem with tractor is the M6 alarm.
   / Deutz Fahr Agro Plus 67 (2013) hydraulics #2
Build yourself a hydraulic system pressure gauge and test the live pressure in as many places as you can, both hot and cold.
Make a thoughtful table of the recorded values and see where the information takes you.
It may be a priority valve malfunctioning. Or a Pressure regulator not behaving properly. "filters or the exact type of fluid? I doubt it!
Thanks for your reply. I ordered a test gauge this morning. Should have it Friday or Monday.
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
JOHN DEERE TS LOT IDENTIFIER 138 (A53084)
JOHN DEERE TS LOT...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
