Deutz D10006A
   / Deutz D10006A #1
Bradlyk
Bronze Member
Grey County, Ontario
Ford 3930, Ford 6600, Agco Aliss 5670, Deutz D10006, Deutz D10006A
Hey guys,
Thanks alot for help with my Ford 3930 ( Will keep you notified when it gets out) but today I'm having a day off sort of speak (Sunday) anyways a few months ago by D10006A went in for a new PTO Clutch and when I got it back I parked it for the night and the next morning I turned the ignition on and before I got to turning over the motor the horn was "BLARING" wouldn't shut up until I turned off the ignition again... Since I had to go get bailing I opened the hood and unplugged it .. Anyways do you guys think you know what is wrong with it . I would like to get it fixed now since I have the time
Thanks in Advance
   / Deutz D10006A #2
Does that model have the horn on the end of turn signal controller or does it have the horn in the center of the steering wheel?
   / Deutz D10006A #3
Probably push button is stuck or shorting out of wires somewhere in the circuit...
   / Deutz D10006A
Neither next to the steering wheel their is a little stick thing and at the end their is a button
And no its not stuck as I can push it
   / Deutz D10006A #5
Hi! I think on some tractor Horn can be a WARNING device. Check engine oil tranny differential hydro oil.etc.. .Check wiring thermostat pressure gage and sender glow plugs etc Dont run! before find the trouble If engine or tranny is missing oil ? Good luck Oldmech
   / Deutz D10006A
No their isn't any problem it has been running fine for the past to months and every time I connect the horn back up it does the same thing
   / Deutz D10006A #7
I would check our 130-06 but it is buried in a snow bank... From what I remember the horn is actually located at the front maybe even connected to the front of the lift hood? I would make sure wires are not damaged anywhere.... As far as i know there is no relay but that would be something to look for.. I would not worry about it being a warning as those have transmission and engine pressure lights .. The only warning sound is for getting too hot and only if yours is fitted with a warning horn on the tension pulley for the main belt in case it breaks... Good luck and keep looking
   / Deutz D10006A
Hello and you are totally correct the horn is at the front of the hood. And I am not worried as this tractor doesn't have the safety horn etc its not a 2011 tractor lol. I just want to know how to fix the wire or where is it broken etc
Thanks a bunch for everyones help and hopefully I will "get er done"
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2021 KOMATSU WA380-8 WHEEL LOADER (A60429)
2021 KOMATSU...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2022 John Deere Z930M (A57148)
2022 John Deere...
